Home > Technical (L322) > Sump |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Hi all,
27th Jan 2017 12:48pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Assuming that they are fitting genuine parts, then the discs and pads will be about £200 fitted so they're charging you £100 for the leak.... bearing in mind that even if it's the sump plug washer your going to loose the oil when it's changed, I'd say thats reasonable..... but if that price is for a clean up and a squirt of jollup then it's a bit steep..... it all rather depends on what is leaking and how they are going to fix it...
27th Jan 2017 1:18pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1537 |
You mention the petrol V8 strip the sump like plug thread. We did an oil change on mine last week and pulled the lower sump cover to check for bits of plastic timing chain guide in the sump (none ).
15th Jan 2018 6:08am |
I'd have a look at this!! http://www.fullfatrr.com/forum/topic31702.html Either read the whole thing or look at this http://www.quickvalve.co.uk/
15th Jan 2018 9:21am |
And you should find this lot a little closer to home!! http://fumoto.com.au/info.htm Yesterday I couldn't spell Engineer... Today I are one!
15th Jan 2018 9:38am |
Thanks miggit. I was right M12x1.5. I'll have a look to see if the valve is available locally **. Some UK suppliers charge a small fortune to ship to Oz, others are really quite reasonable. Quickvalve seem to charge only 3.6 quid.
15th Jan 2018 9:48am |
I have also discovered this lock for the valve....
15th Jan 2018 10:01am |
I'd buy the lock, to be sure, to be sure. Ron B. VK2OTC
15th Jan 2018 10:20am |
^ Pt no's LC-10, and LC-15... in the extras on the order page!
15th Jan 2018 10:26am |
