![]() | Home > Technical (L322) > Sump |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Hi all,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Assuming that they are fitting genuine parts, then the discs and pads will be about £200 fitted so they're charging you £100 for the leak.... bearing in mind that even if it's the sump plug washer your going to loose the oil when it's changed, I'd say thats reasonable..... but if that price is for a clean up and a squirt of jollup then it's a bit steep..... it all rather depends on what is leaking and how they are going to fix it...
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
You mention the petrol V8 strip the sump like plug thread. We did an oil change on mine last week and pulled the lower sump cover to check for bits of plastic timing chain guide in the sump (none |
I'd have a look at this!! http://www.fullfatrr.com/forum/topic31702.html Either read the whole thing or look at this http://www.quickvalve.co.uk/
And you should find this lot a little closer to home!! http://fumoto.com.au/info.htm Yesterday I couldn't spell Engineer... Today I are one!
Thanks miggit. I was right M12x1.5. I'll have a look to see if the valve is available locally **. Some UK suppliers charge a small fortune to ship to Oz, others are really quite reasonable. Quickvalve seem to charge only 3.6 quid.
I have also discovered this lock for the valve....
I'd buy the lock, to be sure, to be sure. Ron B. VK2OTC
^ Pt no's LC-10, and LC-15... in the extras on the order page!
