Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
You can see from my pic above, the central part just pulls out. Ron B. VK2OTC
29th Dec 2017 8:00am |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
I believe ohuntsman is talking about the cast part that holds the heating element. In order for his to be in a different orientation the heating element would need to be redesigned and or the functioning guts would need to be redesigned which just wouldn't be cost effective. That leaves us with the new modified thermostat made wrong or installation error. |
29th Dec 2017 1:44pm |
That central heating element part goes up inside the thermostat. The wiring on mine had corroded away so it just pulled out.
29th Dec 2017 10:27pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If you go back to my post on the 2nd of Jan last year I ordered one of the BMW 88 deg ones. http://www.fullfatrr.com/forum/topic39362-30.html
6th Jan 2018 1:22pm |
In my search to find a cheaper option I found the 740d is the identical housing with the lower temp and heating element port capped off. Just wasn't a cheaper option. |
6th Jan 2018 2:56pm |
Deltaevo Member Since: 02 Apr 2017 Location: Ashbourne Posts: 39 |
Thanks for the explanation, I’ve found one for a reasonable price
6th Jan 2018 9:36pm |
If you use the 740d thermostat you have removed where and why you have that connector. With this change most just move the connector out of the way. It will trigger a code but most of the time it doesn't trigger a service engine soon light. Mine did/does trigger a stuck thermostat code that does need to be cleared. I installed a resistor as per instructions from the guys that make the modification but sill it happens from time to time. |
6th Jan 2018 10:57pm |
Thanks my sensor has been broken for awhile, so no code is generated. In reality what does the sensor do. In the long run is this in anyway detrimental to the system? |
6th Jan 2018 11:12pm |
If you are talking about the plug on the thermostat it’s not a sensor but a heater.
7th Jan 2018 12:25am |
Thanks for the explanation |
7th Jan 2018 12:30am |
Yes but the system also senses if the element is heating by measuring resistance. Hence the codes without proper resistance. Not sure my 10 ohms 100w resistor isn't doing the job 100% of the time. |
7th Jan 2018 5:24am |
I get an electric thermostat open circuit fault logged but it doesn’t effect anything and doesn’t cause the EML light to come on, I just waterproofed the disconnected cable and tucked it out the way.
7th Jan 2018 9:16am |
60 x 16 mm body size for the resistor so it is no light weight. By theory the ECU finds the closed circuit provided by the resistor and thinks all is well. The open circuit would be the problem. |
7th Jan 2018 3:46pm |
That's not a resistor thats a telegraph pole |
7th Jan 2018 5:10pm |
