Home > Wheels & Tyres > Wheel nuts for different alloys Guide
Page 3 of 4 <1234>
Wheel stud thread is the same for all L322 ie M14x1.5mm. Thumbs Up
Post #328624 19th May 2015 3:14pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Thanks! Very Happy NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #328626 19th May 2015 3:21pm
itguy wrote:
Wheels and wheel nuts (KIT or standard equipment) used on 2003 2005 MY Range Rovers must not be used on 2006 MY vehicles.
Hmm, is this correct?
I've a set of 2005 (or so) 19" wheels. Will these not fit my 2007 model if I use the old style nuts, or is the actual wheel also incompatible?
Post #457713 18th Nov 2017 12:40pm
the nut on the left has a smaller shank and is for wheels from 2002 to 2005..
the nut on the right has a 23mm shank and is used on 2005 onward wheels ,including RRS ones...
your 19'' wheels can be used with the smaller nuts but i would try the '2007' wheel nuts cos they will be ok if the wheels are later types.. ... - .- -.
Post #457726 18th Nov 2017 2:14pm
Thanks Stan. I understand the difference in the nuts.
The nuts for my 20" wheels don't fit my 19" wheels - nuts too big!.
But the issue is just the nuts - if I use the earlier nuts and earlier wheels on my 2007 there shouldn't be an issue? At least that's what I thought until I read ITGUY's post - is he wrong?
Post #457757 18th Nov 2017 6:34pm
the stud threads are the same so i cant see how he can be right...the only problem ,if there is one , would be your discs being to big... ... - .- -.
Post #457760 18th Nov 2017 6:45pm
They're not too big.
Thanks, I'll order some new nuts!
Post #457770 18th Nov 2017 7:51pm
Just to confirm the above is well intentioned but erroneous advice. You can run pre 2006 wheels on a post 2006 L322 so long as you use pre 2006 nuts. The only possible issues are with brake clearance (which I think only affects 18" wheels, and also the TPMS, which you can disable with the IID tool.
Post #458591 26th Nov 2017 3:44pm
wack61
Right that's confused me
I have a 2003 L322 with 18" wheels , just bought a set of 19" wheels from a 2010 L322
My nuts are black , do I need the bigger nuts or will the black ones fit, it's cold outside so I don't want to change them to find out I don't have the correct nuts Very Happy
Old wheels
New wheels
Post #462306 27th Dec 2017 1:28pm
generally any wheel from 2005'ish will have the bigger nuts, RRS or FF.. ... - .- -.
Post #462307 27th Dec 2017 1:30pm
wack61
That'll do for me, thanks Stan, I'll order some of the bigger ones
Post #462312 27th Dec 2017 1:57pm
Danwilderspin
Wow - post resurrector here
Just a quick one I am looking at some aftermarket hawke alloys with the black studs be ok or do I need silver? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #468750 15th Feb 2018 4:37pm
Danwilderspin
Here is the lug looks flat at the base so should black be ok?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #468952 16th Feb 2018 10:12pm
I would think if they are Hawke wheels they would take 06> nuts NOT the pre <06 black nuts... Hawke have only been around a short (ish) time so i wouldn’t think they would have made wheels pre the 06 uplift... Thumbs Up
Post #468957 16th Feb 2018 10:57pm
Danwilderspin
Is there a way to see if they would fit aren’t they the same size lengthwise just tapered? In which case if the wheels are flat and wide enough both would fit? Or am I missing something? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #468960 16th Feb 2018 11:56pm
Page 3 of 4 <1234>
