![]() | Home > Wheels & Tyres > Wheel nuts for different alloys Guide |
Wheel stud thread is the same for all L322 ie M14x1.5mm. |
Hmm, is this correct? I've a set of 2005 (or so) 19" wheels. Will these not fit my 2007 model if I use the old style nuts, or is the actual wheel also incompatible? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35661 ![]() ![]() |
Thanks Stan. I understand the difference in the nuts.
the stud threads are the same so i cant see how he can be right...the only problem ,if there is one , would be your discs being to big... ... - .- -.
They're not too big.
Just to confirm the above is well intentioned but erroneous advice. You can run pre 2006 wheels on a post 2006 L322 so long as you use pre 2006 nuts. The only possible issues are with brake clearance (which I think only affects 18" wheels, and also the TPMS, which you can disable with the IID tool. |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 ![]() ![]() |
Right that's confused me I have a 2003 L322 with 18" wheels , just bought a set of 19" wheels from a 2010 L322 My nuts are black , do I need the bigger nuts or will the black ones fit, it's cold outside so I don't want to change them to find out I don't have the correct nuts ![]() Old wheels
New wheels
generally any wheel from 2005'ish will have the bigger nuts, RRS or FF.. ... - .- -.
That'll do for me, thanks Stan, I'll order some of the bigger ones |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Wow - post resurrector here
Here is the lug looks flat at the base so should black be ok?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
I would think if they are Hawke wheels they would take 06> nuts NOT the pre <06 black nuts... Hawke have only been around a short (ish) time so i wouldn’t think they would have made wheels pre the 06 uplift... |
Is there a way to see if they would fit aren’t they the same size lengthwise just tapered? In which case if the wheels are flat and wide enough both would fit? Or am I missing something? Current stable:
