Home > Maintenance & Mods (L322) > 4.4 tdV8 Sucker
Baltic Blue
4.4 tdV8 Sucker
Father Xmas has given me a sucker.
I can’t wait for a bit of warm weather when I will be trying it out.
Post #462214 26th Dec 2017 1:50pm
surely a colonoscopy would be better at a hospital!! Shocked Mr. Green
Wink ... - .- -.
Post #462215 26th Dec 2017 1:53pm
nino_nino
BB, don't you mind Stan, you are gonna have such a fun with that sucker Laughing
Post #462218 26th Dec 2017 2:56pm
Baltic Blue
Nino,
£83.00 for 10 litres of oil and replacement filter, I will have the last 😂 all the way to the bank.
Happy New Year to both of you, and Adrian for the recommendation.👍👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #462220 26th Dec 2017 3:14pm
nino_nino
You may start changing oil every 5K km like i do, and there are so many other thinks you can use that sucker for. Thumbs Up
Post #462224 26th Dec 2017 3:58pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Nice one BB - they are brilliant. Changing oil on any of the families cars is so simple now and as you say with the opie oil discount oil changes are cheap!. Ade. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #462239 26th Dec 2017 6:58pm
SinbadRose
So stupid question time, I take it without the dipstick on the 2011 you will be going in through the oil filler? Take it you can still get all the way to the bottom with it?
Post #462292 27th Dec 2017 12:07pm
Baltic Blue
Sucking the old oil out is simple.
The engine has a tube in place specifically to suck oil out without the need to crawl underneath to remove a sump plug.
Perfect for old men like me with a bad back😁👍
Post #462293 27th Dec 2017 12:26pm
SinbadRose
Excellent, thanks for the quick reply. I may look at one for the future, as I would like to change the oil every few months/5k ish myself. I am with you on the old and bad back part Sad Looks like a really handy bit of kit.
Post #462294 27th Dec 2017 12:44pm
Simbad... Pretty much the only way to change engine oil in a 2011 & newer FFRR is to suck it out... Its how JLR designed them all now a days Thumbs Up
Post #462328 27th Dec 2017 4:09pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Excellent machine , 115 stg , well worth it 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #462362 27th Dec 2017 7:42pm
GGDR
Thought I'd remembered an old thread on draining vs sucking and found this:
http://www.fullfatrr.com/forum/topic41966.html
stan wrote:
according to the WM you can disconnect this pipe to drain the oil rather than using a vacuum..
Thoughts?
Greg Cheers, Greg
Post #462410 28th Dec 2017 10:01am
Baltic Blue
Greg,
I was aware of the hose method, but because both Adrian and Nino have said in previous posts just how easy and clean it is to suck the old oil out, and I am getting a bit old for crawling underneath, I opted for the sucking method and intend to do it twice a year.
Opie have got 15% off service packs at present. I have just got 10 litres of Shell AF L. plus filter for £ 80 incl delivery.
Post #462414 28th Dec 2017 10:25am
nino_nino
Greg, first time I changed oil in my car was like that, bit messy, then i realise that the same pipe i disconnected to drain oil is the pipe you hook up the sucker to extract oil, soo same thing - you get same amount of oil out either way. i do drain oil from the small pocket above crossmember (every 3d oil change).
as for changing oil at 5K km intervals, it cost me only 70 quid - filter included ( mobil 1 0/40) . and it is fun Very Happy ( and I can swear she runs sweeter after).
nino
Post #462418 28th Dec 2017 10:46am
GGDR
Sure - seems like there are benefits to sucking.
I'm a bit jaded having changed the oil many many times on my boat (twin engine, so double the fun) where normal practice is to suck it all out through the dipstick. Marine engines don't tend to have sump drain plugs. You normally hook up a 12v oil pump then wait while it refuses to suck for 20-30 mins then eventually using some kind of black magic it starts to pump out then you babysit it for an hour to make sure the pipe doesn't pop out while pumping then you try to work out if you've sucked enough using the various bottles you've filled then you do the filter and then do it all again on the other engine.
The whole time, every time, I'm just thinking I've love to drop the oil using gravity alone using an old fashioned sump plug.
But maybe this oil pump out pipe on the our 4.4's is a bigger bore than the dipstick tube on my Volvo Penta marine engines and it's a doddle. You guys make it sound so.
For just £70 or £80 (Great deal from Opie!) - it's the best bit of maintenance you can do right?
I've only done 4k miles in mine since Feb when I bought it. So 5k / annual seems good for February. I'll do the trans, diffs and transfer box too.
Mike, where do you get rid of your old oil? Local garage or does your council have somewhere?
Greg Cheers, Greg
Post #462426 28th Dec 2017 11:26am
