Home > Maintenance & Mods (L322) > Seized pins in callipers extra six hours labour |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
Ouch 2006MY 4.2 SC
16th Dec 2017 5:27pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Apparently copper grease causes steel pins to seize in aluminium calipers?
16th Dec 2017 6:18pm |
smudge68 Member Since: 27 Oct 2016 Location: UK Posts: 40 |
I replaced mine (2011 with 50k miles) a couple of months ago and had exactly the same - what should have taken me a couple of hours at the most turned into a full weekend job to remove and drill out. Really pleased I didn't leave it to the dealer now....! |
16th Dec 2017 6:28pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
6 hours! OUCH!
16th Dec 2017 6:29pm |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Apparently he tried all sorts of ways to drift those pins out, they had to drill the pin a bit, split it and bend the sides in and out to break it and remove the pin, bit by bit as it was seized solid all the way down.
16th Dec 2017 7:11pm |
I'm guessing you haven't seen just how seized these pins get. I did dremel, and using a drift to get them out with the calipers on the car or on the bench would not move them, it's like they have been welded into the calipers. Even drilling them out was a heck of a job. |
16th Dec 2017 7:20pm |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
Exactly what I did... didn’t cause me too much bother. Worrying about the copper grease comments as I greased them right up with slip. |
16th Dec 2017 7:28pm |
Well i do them weekly (ish) and granted some are easier than others! |
16th Dec 2017 9:10pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1369 |
I've read that copper grease isn't the best for in around the brake area due to it drying up with caliper temperatures and that it's better to use caliper / lithium grease stuff.
16th Dec 2017 11:39pm |
Fisha, you have the 4 pot callipers not the 6 pots this thread is complaining about sir |
17th Dec 2017 12:12am |
Phew !
17th Dec 2017 8:18am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1534 |
What is this rust of which you speak?
17th Dec 2017 8:34am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Salt off the roads not helping this probably...
17th Dec 2017 9:08am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
Exactly the same happened with my last 4.4 TDV8 - and these were well and truly corroded solid - due to loads of salt on the the roads here. Main agent sorted for an additional 1 hours labour - cut the head and tails off the pins and a 20 ton bench press pushed them out with a drift.
17th Dec 2017 9:17am |
