Home > Maintenance & Mods (L322) > Seized pins in callipers extra six hours labour
Page 2 of 3 <123>
mpirie
I had the same problem, but admittedly on only one pin.
Like CTC, I cut the pin centre out.
Since the pins only go in from the inside out, I was then able to drift the outside part of the remaining pin inwards until it came out, then used a long punch through from the outside to reach the inner part of the pin, using the hole as a guide.
With hindsight, it appears the the siezing came from the barrel spring that's used to stop the pins falling out. Probably an electrolytic corrosion reaction.
Freddie/Cavalier, I wouldn't worry about having them fitted with Copaslip, it looked like my originals had been fitted dry, so any lube would be better than none.
Mike
Post #461121 17th Dec 2017 11:24am
Baltic Blue
From what I have read, the copper speeds up the electrolysis process with the 3 metals forming a “battery” effect once they get wet, and any salt in the “electrolyte “ makes the problem even worse, but I am sure you are right, taking them out every 6 months and re-inserting them with just a touch of grease is the best solution.
Cheers
Post #461125 17th Dec 2017 11:40am
miggit
Whistle All I can say is 6 hours labor from Woburn 4x4 is about 2.5 hours LR rates, and knowing the chaps down there if there was a way to do the job on the car they would have... they have work rounds for most LR jobs especially the body off jobs for the Discos and RRS...
I can only imagine that the pins were so bad they needed to go in a drill press... don't forget we are talking steel pins in an ally caliper so one slip with the drill and it's new caliper required Shocked It never ceases to amaze me just how badly calipers are made.... you'd have thought that the manufacturers would have found a solution to electrolytic action, rust and heat.... obviously they are too busy selling replacement calipers to care Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #461135 17th Dec 2017 1:12pm
Mikey
It's a little concerning, that a pin that is held in place by friction, is having grease applied to it Shocked
Post #461142 17th Dec 2017 2:13pm
miggit
They are held in place by the spring that locks them using the wide groove in the middle of the pin.... I suppose it's a step up from a pin with a locking spring or a split pin, but only just.... For what is classed as high performance braking it's a rather low tech solution!
And the fact that they corrode means they are steel, why don't they use stainless steel for the pins? the cost would be pennies, but the advantages would be great...... One day Carlsberg might do brakes Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #461153 17th Dec 2017 4:12pm
mpirie
Maybe the pins and anti-rattle springs are considered sacrificial items that should be replaced at the same time as the pads?
I agree, having such a weight of vehicle with such momentum being stopped by such a penny-pinching setup is incredible.
Makes you wonder how many cars are out there on VERY worn pads? Or as the OP states, are being relieved of their cash for something so poorly thought through.....oh, wait, this is Land Rover we're talking about!
Mike
Post #461161 17th Dec 2017 5:27pm
TomCobbly
I had the same problem and cut the pins to get the pads out and then managed to get my ball joint splitter on the remaining stumps and pressed them out. They didn't half make a bang when they let go!
It was a bit tricky setting the tool flat but apart from that it was straight forward. Very Happy 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #461218 18th Dec 2017 9:38am
mpirie
Just as an aside, you can still replace the pads providing you only have one pin siezed.......simply remove one pin, then take the caliper off the hub mount.
I know it''s not the done thing but could help someone if you're half way through the job and get stuck.
Mike
Post #461230 18th Dec 2017 10:43am
Baltic Blue
Just wondering, has anyone found a suitable “G” clamp device for pushing the pins out ?
Post #461237 18th Dec 2017 11:20am
p38arover
Australia
Back in the mid-90s, I was in charge of some building repairs on a submarine cable station on Norfolk Island in the South Pacific. I asked the same question of the structural engineers we had contracted because many of the steel bolts holding all the steelwork together were severely rusted.
The engineer replied that with the salt laden air**, stainless steel would cause greater problems. The gist of it was, that it was better for the steel bolts to slowly and visibly fail than to have the structural steel corrode at the bolt holes - sight unseen.
** the building was at the top of a cliff with a waves breaking on the beach at the bottom. The wind brought the salt laden air straight up and onto the building. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #461239 18th Dec 2017 12:08pm
^ I agree re the comments about salt laden air. As I live next to a beach it is a serious problem such that each year I dismantle the brakes on the cars, clean them up and use a general purpose grease to reassemble. Never had a problem with corroded components yet. Used to be the same when I lived in Scotland, the damper winter combined with excessive use of salt on the roads caused same problem. I also grease the brake pipes to avoid similar corrosion problems, must work as I have never replaced a brake pipe in my life. Thumbs Up
Post #461240 18th Dec 2017 12:30pm
TomCobbly
Baltic Blue - something like this worked for me!
Post #461251 18th Dec 2017 2:14pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
this just seems like they need to be removed periodically to prevent this kind of thing happening
Post #461255 18th Dec 2017 2:51pm
miggit
from what I can see there is very little in the way of a flat surface perpendicular to the pins, so it would be next to impossible to get a straight push, which would increase the likelihood of damaging the caliper or jamming the pin Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #461284 18th Dec 2017 6:22pm
TomCobbly
Unnecessary quote removed
I know what you mean about the flat surface and I seem to remember shimming it out somehow to get the geometry right. Trouble is I can't remember what I used to do it. Embarassed 2011 4.4 TDV8 Vogue SE
Post #461326 18th Dec 2017 9:22pm
Page 2 of 3 <123>
