Home > Technical (L322) > Another FBH issue |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Similar at times since i changed dosing pump but the FBH exhaust is always blowing red hot but at times hasn't got warm in cab unless it needs like 20 mins but didnt before _____________________________________________________
26th Nov 2017 10:54pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
I can't remember the parameters, but has it always been cold enough for the FBH to actually need to generate heat?
28th Nov 2017 1:04pm |
Bumperchaser Member Since: 11 Dec 2017 Location: Berkshire Posts: 4 |
I am having similar issues.
11th Dec 2017 1:41pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Just my pennies worth , I've had my 2011 for about a month now and had similar issues with tthe FBH with low battery warning coming up. So bought a new AGM , notified the car via IID tool and the fbh is now working perfectly but it took about a week after the fitting of the new battery for the FBH to work every time , remote or screen setting up wise. 2015 4.4 AB
11th Dec 2017 7:00pm |
Excellent!
11th Dec 2017 7:57pm |
Hi John , i use my FBH 4 or 5 times a day. It's great at this time of the year. I agree about having every thing working but the FBH is fantastic when working correctly.
11th Dec 2017 8:04pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Hi John, I too was wondering about the manual heat setting greyed out on the head unit, until I discovered these become operational when the ignition is switched off and you turn the head unit on by the standby button. Chris |
11th Dec 2017 8:51pm |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
Unnecessary quote removed
11th Dec 2017 10:12pm |
Ok, so further to my last:
12th Dec 2017 12:54am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Just a cheeky bump to my original post, we've drifted around, AGM batteries etc...
17th Dec 2017 6:15am |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
Even though I've got a new battery my FBH seemed to either only work for a short time or attempt to start and then shut down. To test it I attached a remote power supply like the ones recommended by GAP when using the IID with the engine off and tried again. It ran perfectly but I noticed it was drawing 20 amps from the power supply.
18th Dec 2017 8:56am |
