Home > Technical (L322) > FBH FUEL PUMP
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
FBH FUEL PUMP
hello chaps im asking for info my FF went for M.o.t yesterday passed too i might add but the tester said i have a very small diesel leak above the rear diff dropping on to the drive shaft and i looked under when i got home and i can see a small looking pump with a square plug 2 pipes one end is very rusty but the pump doeset pump it pulses if you will ! Am i right in thinking its the fuel pump for the FBH when it pulses you can just see the end of the pump next to the 12v plug weaping fuel are these expensive and easy to swap and will one off a x5 or similar work thanks
Post #459442 3rd Dec 2017 3:31pm
Johnsd1v8
Anyone ?
Post #459501 3rd Dec 2017 10:30pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I swapped out my FBH pump about 6 weeks ago as it was leaking. They cost about £220 from Land Rover. In addition to the pump you will also need 2 hose clamps
It is pretty easy to swap if you are handy with the spanners and it can be done with the RR in off-road height, you don't need to take the wheels off.
Just unbolt the old pump, remove the pipes and electric connector. It is a little awkward as you need to work with you arms either side of the rear diff. Just the reverse to put it back on.
One of the ends came off my pump when I was changing it which made the job even easier 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #459507 3rd Dec 2017 11:55pm
Johnsd1v8
Thankyou andy looks like ill give landrover a call 👍
Post #459517 4th Dec 2017 5:53am
Andy_J
Try Dan @ Duckworth, he was cheaper than my local dealer (Less than £200). Mine was leaking so badly I ended up having to buy it from my local dealer
Link to my post which contains some instructions from other members
http://www.fullfatrr.com/forum/topic44844.html 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #459525 4th Dec 2017 8:50am
Johnsd1v8
Thanks andy ive seen a couple from bmw x5’s on flea bay they look the same as mine but its take ya chance on ebay isnt it
Post #459526 4th Dec 2017 9:12am
Andy_J
Seem to remember the pump has 'Wabasto' stamped on it so probably is common to an X5, didn't think to check part numbers at the time 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #459774 5th Dec 2017 11:48pm
Rewmer
Please don’t pay dealer prices. Get one for a webasto thermotop c from eBay. No7 - 2003 V8 Vogue
Post #459836 6th Dec 2017 6:16pm
Johnsd1v8
Thanks guys 👍👍
Post #459846 6th Dec 2017 6:54pm
Johnsd1v8
I seen this on ebay from a x5 looks excactly same as mine what do you chaps think
Post #459857 6th Dec 2017 8:01pm
Rewmer
Thats the badger No7 - 2003 V8 Vogue
Post #459858 6th Dec 2017 8:13pm
Johnsd1v8
Brilliant thats £35
Post #459863 6th Dec 2017 8:49pm
Johnsd1v8
Is it just a case of swap it out ? I asume theres no bleeding required
Post #459867 6th Dec 2017 8:56pm
Rewmer
Yep, just swap it out. They are self bleeding. It may need a couple of cycles to clear any air. No7 - 2003 V8 Vogue
Post #459876 6th Dec 2017 9:14pm
garyRR
Bumping this Thread to see if someone could take a photo of the FBH fuel pump assembly above the rear diff?
It's been removed on my car and I'd like to re-instate so, need to know how it all fits. 2015 Range Rover Autobiography 4.4 SDV8
Post #609533 17th Oct 2021 10:51pm
