![]() | Home > Technical (L322) > FBH FUEL PUMP |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
Anyone ? |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I swapped out my FBH pump about 6 weeks ago as it was leaking. They cost about £220 from Land Rover. In addition to the pump you will also need 2 hose clamps
Thankyou andy looks like ill give landrover a call 👍 |
Try Dan @ Duckworth, he was cheaper than my local dealer (Less than £200). Mine was leaking so badly I ended up having to buy it from my local dealer
Thanks andy ive seen a couple from bmw x5’s on flea bay they look the same as mine but its take ya chance on ebay isnt it |
Seem to remember the pump has 'Wabasto' stamped on it so probably is common to an X5, didn't think to check part numbers at the time 56 TDV8 Vogue SE
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Please don’t pay dealer prices. Get one for a webasto thermotop c from eBay. No7 - 2003 V8 Vogue |
Thanks guys 👍👍 |
I seen this on ebay from a x5 looks excactly same as mine what do you chaps think
Thats the badger No7 - 2003 V8 Vogue |
Brilliant thats £35 |
Is it just a case of swap it out ? I asume theres no bleeding required |
Yep, just swap it out. They are self bleeding. It may need a couple of cycles to clear any air. No7 - 2003 V8 Vogue |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Bumping this Thread to see if someone could take a photo of the FBH fuel pump assembly above the rear diff?
