Home > Technical (L322) > 4.4 tdv8 12MY reluctance to start
Page 3 of 3 <123
GraemeS
Australia
Has the starter relay been replaced?
Post #459357 2nd Dec 2017 7:50pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
Yes. Fully covered under wartanty. Still occasional non starter. Very annoying,
Regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #459359 2nd Dec 2017 8:09pm
GraemeS
Australia
Just confirming, I'm referring to the relay in the fuse box, not the solenoid attached to and part of the starter motor itself.
Post #459375 2nd Dec 2017 10:41pm
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
I'm having a similar problem, non starter at the moment although I've not tried 22 times. Disconnected the starter cable from the mega fuse and high resistance to earth when the solenoid is engaged. Resistance of the solenoid coil to earth from the start relay is 1.2 ohm which seems a bit high, measured a solenoid coil on a spare starter at 0.3 ohm. Perhaps it's the wiring between the the start relay and solenoid or a bad earth, not quite got that far yet.
Post #459377 2nd Dec 2017 10:57pm
TomCobbly
I posted this a few days ago and it worked for me. Now I always park with the steering centered and never happened since.
http://www.fullfatrr.com/forum/topic45404.html 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #459554 4th Dec 2017 2:26pm
Wizz991
Can you not just put new contacts in the solenoid I have done loads of td5 discos and freelander 2s
Post #459624 4th Dec 2017 11:04pm
Page 3 of 3 <123
