Home > Technical (L322) > Webasto T91 changing to heat question
Page 3 of 3 <123
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
This is the part ( that you will need if after stripping and cleaning yours it is no better.
http://www.webastomarine.co.uk/shop/vclose...4&fo=1
There is a detailed description of the servicing on the www.the75andztclub.co.uk. But you will need to be a member to access the how-to section
[/url]
Post #459365 2nd Dec 2017 8:17pm
Heathy
United Kingdom 2011 Range Rover Vogue SE TDV8 Fuji White
Gumball3000 wrote:
berkshirelad wrote:
The FBH is the same as the Rover 75,
If it stops after 2-4 minutes then the FBH glow plug resistance is too high (maybe gone open circuit) so the system shuts itself down to protect itself.
Seems like this is the same issue i am having , how do i fix it ?
Me too Big Cry
I have a brand new battery on it so I've ruled that out.... Vogue SE 2011 MY 4.4TDV8 in Fuji White
RSE, Surround Cameras and Deployable Side Steps
Post #459389 2nd Dec 2017 11:37pm
Zeppfish
Guys try an error lockout reset of the FBH and see if that works! I have taken the following from the webasto workshop manual
So pull fuse 13 for 3 seconds and replace, then wait a few seconds and press the on button on the remote control.
After another 3 seconds pull fuse 13 again for 3 seconds and replace, the FBH should now start!
Make sure before all of this that you guys with remote issues have your key fobs paired to your units properly,
Dan 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #459401 3rd Dec 2017 6:00am
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Another update.
I have done the fuse pull as suggested on the previous post , and all seemed to work.
The burner fired up ran for about 2 mins then the blowers in the car started to blow but then it all seemed to shut off.
So i re started it all again but this time i watched the climate control panel inside the car an saw the auto light flash a few times and then go off.
I tried a third time this time sitting inside the car , as i heard the blower motor engage i felt the vents but there was nothing at all coming from any of them.
So i am suspecting that it may be a hevac issue not opening the vents.
The heater works fine when the car is in normal use so i dont know what could be the issue. Big Cry Big Cry
Post #459443 3rd Dec 2017 2:33pm
Gumball3000
Following the last post , i have checked my heater and it doesnt blow at all when it set on auto mode but is fine when you manual press the direction buttons.
So i am guessing that this may be the problem.
Post #459449 3rd Dec 2017 4:23pm
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I have just purchased the keyfob for my 2011 vogue, and i am dreading trying it. I always get the low battery warning even when i open the door from being parked up. Had a new agm battery a couple of months ago, and seems no better with the low battery warning issue. Seems a bit pointless putting a heater on a car like this that is meant to run for 30 mins, when the system will shut it down after 4 mins even with a good battery.
Post #459491 3rd Dec 2017 9:00pm
Page 3 of 3 <123
