![]() | Home > Wheels & Tyres > New tyres on front or back? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
its a 50/50 drive on the FF so it won't make any difference...my personnel view is to put your new ones on the back, leave the fronts as they are.... ... - .- -.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Thanks for that will leave the fronts where they are |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
"Best on the back"is the mantra.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1415 ![]() ![]() |
Best on back. It mitigates the rear breaking away from you and tail sliding out which is harder to control in theory compared to understeer. V8 or else ... |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 813 ![]() ![]() |
Manufacturers say the rear.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
'Best on back' is a theory I wouldn't have thought of at all. On a 2.7 tonne Range Rover I'd have thought under braking you'll need best on front. But I'm no expert - was just surprising to hear that theory.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
Front tyres wear out quicker - and so do the shoulders. In your position I would put the new set on the front. If the other pair are that worn it would make that much difference putting the old set on the front and the new set on the back then they shouldn't be on the car. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
New ones on the back. That is the "rule", As already advised. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
That advice must date back decades...... still a reasonable default though - most drivers can’t handle oversteer, whereas understeer is far easier to contain.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Only my opinion but I always change all 4 and never go below 3mm just my choice - |
+1, I rotate my tyres so they wear evenly and only buy a full set. The last set came off with 5mm - 6mm on and were sold as part worn, but they were Generals AT's which have around 11mm tread when new. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
All 4 together for me too - doesn’t really help with the question though |
thanks for the replies. The fronts have about 7 mil left on them so will just stick the new ones on the back which they are replacing as thats the easiest thing. Current 2007 TDV8 Vogue Buckingham Blue |
