Home > Wheels & Tyres > New tyres on front or back?
kbald
Hi all i need to replace the rear tyres but the fronts have plenty of rubber left on them. My question is would it be best to have the new rubber on the front and move the fronts to the rear or have the new ones on the rear? Current 2007 TDV8 Vogue Buckingham Blue
Post #459036 30th Nov 2017 1:56pm
its a 50/50 drive on the FF so it won't make any difference...my personnel view is to put your new ones on the back, leave the fronts as they are.... ... - .- -.
Post #459037 30th Nov 2017 2:09pm
kbald
Thanks for that will leave the fronts where they are Thumbs Up Current 2007 TDV8 Vogue Buckingham Blue
Post #459039 30th Nov 2017 2:31pm
bishbosh10
"Best on the back"is the mantra.
This is irrespective of drivetrain.
Not my opinion but that of a police driving instructor so I listen to him! Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #459041 30th Nov 2017 2:42pm
kbald
Thumbs Up thanks for the input Current 2007 TDV8 Vogue Buckingham Blue
Post #459054 30th Nov 2017 4:39pm
fisha
Best on back. It mitigates the rear breaking away from you and tail sliding out which is harder to control in theory compared to understeer. V8 or else ...
Post #459066 30th Nov 2017 5:59pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Manufacturers say the rear.
But the front will wear out faster.
I recently put my new set on the front.
But that was because the old tyres had only done a couple of thousand miles so were close to new...8mm of tread.
So I have nearly new on the rear, and new new on the front.
Post #459277 2nd Dec 2017 10:00am
GGDR
'Best on back' is a theory I wouldn't have thought of at all. On a 2.7 tonne Range Rover I'd have thought under braking you'll need best on front. But I'm no expert - was just surprising to hear that theory.
Greg Cheers, Greg
Post #459278 2nd Dec 2017 10:19am
Vogue
Front tyres wear out quicker - and so do the shoulders. In your position I would put the new set on the front. If the other pair are that worn it would make that much difference putting the old set on the front and the new set on the back then they shouldn't be on the car. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #459303 2nd Dec 2017 12:47pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
New ones on the back. That is the "rule", As already advised.
Post #459335 2nd Dec 2017 4:53pm
That advice must date back decades...... still a reasonable default though - most drivers can’t handle oversteer, whereas understeer is far easier to contain.
However, I’m at least partially with Vogue - as long as the other set are decent, I’d put the new ones on the front and then replace all 4 together.
You have to use a bit of common sense and judgement......
Don’t forget, people also needed to be told not to mix radials and cross-ply - though I still hear people talking about winter tyres on 1 axle, so maybe things haven’t moved on that much Embarassed
Post #459348 2nd Dec 2017 5:36pm
Sandyt
Only my opinion but I always change all 4 and never go below 3mm just my choice -
Post #459409 3rd Dec 2017 8:43am
Vogue
+1, I rotate my tyres so they wear evenly and only buy a full set. The last set came off with 5mm - 6mm on and were sold as part worn, but they were Generals AT's which have around 11mm tread when new. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #459413 3rd Dec 2017 8:57am
All 4 together for me too - doesn’t really help with the question though Whistle
Post #459436 3rd Dec 2017 1:34pm
kbald
thanks for the replies. The fronts have about 7 mil left on them so will just stick the new ones on the back which they are replacing as thats the easiest thing. Current 2007 TDV8 Vogue Buckingham Blue
Post #459446 3rd Dec 2017 4:08pm
