Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG
Page 3 of 6 <123456>
CS
My starter motor needed to be replaced, fault became apparent at about 54,000 miles, 5 years 2 months. Tried to send you a PM but it came up there was no such member (?). Only Range Rovers since 1988
Post #458947 29th Nov 2017 8:33pm
Baltic Blue
CS,
Thanks for info.
I have had a PM from another member this evening so?.?.
Added to my log.
Cheers
Post #458950 29th Nov 2017 8:42pm
mpirie
Hi Mike,
March 2011 VSE, purchased with 46k miles:
Model... 2011 4.4 TDV8 VSE
Fault report: Oil drips from gearbox, smell of burning oil after switching off
Fault cleared by: replacement of turbo feed pipe O rings
Mileage at time of failure: 50k miles
Fault report: Oil showing up in coolant header tank and in V of engine block.
Fault cleared by: Suspected oil cooler failure however turned out to only be the rubber gasket separating the coolant from the oil in the cooler.
Fault report: No air coming from any front vents
Fault cleared by: suspected FSR, replaced FSR, but still no air movement, blower fan needs to be replaced.
Mileage at time of failure: 52k miles
Other: Seized brake pad retaining pin on OSF caliper.....needed to be cut in half and pushed out and replaced.
Other: NSF headlight aiming motor disconnected from reflector. Removed headlight, recovered link arm and replaced.
Regards,
Mike
Post #458960 29th Nov 2017 9:24pm
GGDR
Mike as you may have seen over here:
http://www.fullfatrr.com/forum/topic45347.html
I've had a weird one with oil level readings fluctuating.
Last week I had a low oil level and this week, with only 30 miles driving and not topping up the oil , it's back up to what it was at last check a month earlier.
Oil checked on level ground.
Very odd.
Greg Cheers, Greg
Post #459412 3rd Dec 2017 8:55am
Vogue
Just to add to all these posts, I have just sold my L322 VSE with almost 70k miles. She has been absolutely faultless - no mechanical issues whatsoever.
The only work required has been a replacement tailgate, which could have been touched up (corrosion on the inside) and a drivers seat heater motor - all done under the LR Extended Warranty FOC. To date she had been the best and most reliable RR I have owned.
I hope her replacement is as good Very Happy 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #459414 3rd Dec 2017 9:09am
Baltic Blue
Greg,
I don’t think you have actually got a Fault.
The Workshop Manual describes how the oil level sensor works, and it is so complicated , for such a simple dip- stick job,
The readings can vary widely. Depending on oil temperature, length of time after engine run, to allow oil to drain back to sump etc.
I would follow Nano’s advice and just add oil in 1/4 litre top ups until it reads towards top section.
🤨🤨 You should start a campaign. BRING BACK THE DIPSTICK. 😬😬
Cheers
Post #459417 3rd Dec 2017 9:14am
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Deleted.
Post #459425 3rd Dec 2017 11:07am
Baltic Blue
Gyre8,
Sorry but I am only logging 2010-2012 4.4tdv8 model fault history.
Cheers
Post #459426 3rd Dec 2017 11:13am
Baltic Blue
Vogue,
I wish more owners would report just how good their cars have been.
Members only tend to post when they have a problem, giving the false impression that FF’s are unreliable.
My Td6 Vogue was faultless in over 9 years of ownership, and to- date my 4.4 tdV8 has only had 1 Fault in 20,000 miles since I bought it nearly 3 years ago.
I have always been a believer in regular “over” servicing my cars and it seems to pay dividends.
Best wishes with your new L405 tdV8.
Cheers
Post #459428 3rd Dec 2017 11:26am
Vogue
Thank you Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #459485 3rd Dec 2017 8:24pm
Baltic Blue
Without doubt December has seen a sudden epidemic of Adaptive Dynamic suspension failures. (Mine being one).
I have bought a metre of silicon covered 16 swg. wire in red and white and a similar length of plastic tubing and some heat shrinkdowns to make 2 new wiring looms to replace the original wires. I will post some pictures when I get them fitted.
Seasons Greetings to all 4.4tdv8 members.
Mike. ☃️☃️ 🎅🎅. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #461042 16th Dec 2017 1:59pm
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
Baltic Blue wrote:
Vogue,
Hello BB, just spotted this thread. I have a November 2011 TDV8 Vogue, bought last year (from pld118, a member on here). It had a new suspension compressor replaced under warranty at 44k, software update to cure motorway hesitation at 49k, and a new high level brake light also at 49k. It's now at 54k with no further faults.
Public perception is that all RR's are hopelessly unreliable; I think P38's (and TD6 gearboxes) are the reasons for this. Also older RR Sports which are the same as Full Fats in the public's eyes.
Thanks for creating this thread; interesting reading. It would be good to have Cam-Tech Craig's input.
Post #464884 17th Jan 2018 2:15pm
Fatfred
Hope this input can be helpful Thumbs Up
December 17 @74k the drivers heated seat packed up
following advise from this forum i replaced the seat back blower motor yesterday and now all good
October 17 @72k the heater on the drivers side has become a pain, either full heat or freezing cold, fault is ongoing FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #464890 17th Jan 2018 2:31pm
Baltic Blue
All new fault reports on 2010/12 4.4tdv8’s since Christmas have either been about problems with heated/cooled seats or repeats of problems previously highlighted eg. oil leaks etc. which I suspect will just become more common as our cars age and reach higher mileage’s.
Unless we get a sudden outbreak of a new issue I will now close this thread.
Thanks to all who have contributed and I hope it has been useful.
Cheers
Post #467668 7th Feb 2018 2:10pm
OtleyDominic
Very useful post!
Since having a 2011 RR 4.4 TDV8, I have had the adaptive dynamics fault, a new starter motor, the o ring on the V replaced and 'possibly' the plenum issue causing restricted performance. My RR is only on 65k miles and most of the issues have happened in the last few k!
Post #469297 19th Feb 2018 9:40am
