![]() | Home > My Range Rover > 200k 04 Autobiography and 75k 65 VogueSE |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Amazing well looked after, and not to far off to my list http://www.fullfatrr.com/forum/topic39687.html
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Well my smugness at salvaging the problem with the fuel pump/sender was short lived and last week the gauge packed up again - I suspect one of the cobbled together bits failed again. So stripped down the car again, fumbled around in the tank and replaced it all with a completely new unit. All was good until I went to fill up and the new sender stubbornly told the gauge it was only 3/4 full. Both digital tank read outs in the hidden menu reflected a 75% reading, so looks like the unit was faulty. I did try a full battery reset just to check and ran the tank down and filled up again but no change. Almost looks like the entire unit has been calibrated for a smaller tank but anyway the suppliers are sending another one out.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Great thread |
23/9/17 - 189,778miles
This milestone this morning on the way home.
Treating it to a replacement headlight wiper motor and reversing camera this afternoon. Service in a couple of weeks time. Who knows, it might even get a wash. Current Fleet:- 2018 Discovery 5 3.0 HSE 2021 Ford Ranger Wildtrack 2019 Ford Mustang Bullitt 5.0 V8 1993 Defender 90 200TDI Pickup Gone - not forgotten 2016 L405 4.4 SDV8 Vogue SE 2012 L322 4.4 Westminster 2004 L322 4.4 V8 Autobiography LE 2000 P38 RR 4.0 HSE (ex Clarkson test car) |
Dan - thanks for the comments.
Latest update
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2223 ![]() ![]() ![]() |
Thanks nick - am I being stupid is the cyclone and pcv the same? Also the one on the back of the engine if different I’ve seen a video where you can leave in situ and just change the diaphragm is this an ideas worth doing? How can you best check collapsed pipes? I’m at 160k now... cheers! Current stable:
Also is there a reason you’ve not done preventative on the guides as you j e on a fe other bits? Have you dropped your oil pan to check for plastic? If so is that an easy job Current stable:
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
Dropping the oil pan is straight forward, but I'm not sure there's any point.
I see - if I had any sludge / crap would it accumulate here as well? If the guides were early on failing would I see here? Current stable:
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3209 ![]() ![]() ![]() |
You'd hear it!! Andy (Holday Chicken) on here had a marvellous description, "A noise like a skeleton w@nking in a biscuit tin" |
Lovely description lol - does it slowly come on or does it just sound like that one day? Any idea of the cause? Current stable:
it just goes. Mine went on start up - It had been sitting for a while adn weather was very cold. I think the sudden movement yanked the chain adn that bashed the guide which snapped. |
