Home > Technical (L322) > Is this ticking noise normal? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35361 |
no its not normal ...no idea what the problem is though.. ... - .- -.
20th Nov 2017 4:15pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
Agree with Stan.
20th Nov 2017 5:13pm |
i've been thinking about this..i wonder if its the tensionor on the accessory belt.. ... - .- -.
20th Nov 2017 5:21pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 352 |
desktop diagnosis on a video is going to go from the extreme of 'it's your bottom end knocking, don't drive it,get it looked at asap it's not going to be cheap' right down to 'ye it's the idler pulley, it'll be fine, mines done it for the past 25k'.
20th Nov 2017 6:34pm |
good point Andy ... - .- -.
20th Nov 2017 6:55pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Sounds like idler pulley to me.
20th Nov 2017 6:57pm |
Ps, I'd get it looked at asap regardless. |
20th Nov 2017 6:59pm |
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 |
Thank you, it is booked into the garage tomorrow. They believe it might be the fuel pump, but it is going in nevertheless |
21st Nov 2017 7:12am |
Garage has checked it over and the idler pulleys seem to be the cause |
22nd Nov 2017 12:22pm |
Idler pulleys replaced and the noise remains to some extent. In speaking with the garage apparently the 4.4 tdv8 is a noisy engine and many do have a light ticking? |
24th Nov 2017 8:48pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
24th Nov 2017 10:53pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
My td6 idle pulley fault was very louder and only was at idle. 2010 3.6tdv8 180k km.
25th Nov 2017 7:12am |
The noise remains. After the lr specialist had it for three days, and noise remained, I took it to. LR main dealer who confirmed it didn't sound right. They found the oil overfilled by far, drained it to the right level and then checked codes but nothing explained the ticking. They think it could be related to wrong oil being used, compounded with a high number of dpf regens, putting crap in the oil! I only bought the car two weeks ago with a three month warranty. So it is back to garage tomorrow to see if they can fix it! |
26th Nov 2017 9:41am |
Youtube video of the noise this morning:
26th Nov 2017 11:06am |
