Home > Technical (L322) > Is this ticking noise normal?
OtleyDominic
I have just driven my 2012 4.4tdv8 240 miles over 5 hours and noticed this engine sound when parked up and revved lightly. I also noticed it the other day when going down a hill. Is it normal?
Post #457955 20th Nov 2017 5:10pm
no its not normal ...no idea what the problem is though.. ... - .- -.
Post #457957 20th Nov 2017 5:15pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Agree with Stan.
Not normal.
I get a slight clicking at tick over when cold but nothing after. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #457964 20th Nov 2017 6:13pm
i've been thinking about this..i wonder if its the tensionor on the accessory belt.. ... - .- -.
Post #457966 20th Nov 2017 6:21pm
andygts
desktop diagnosis on a video is going to go from the extreme of 'it's your bottom end knocking, don't drive it,get it looked at asap it's not going to be cheap' right down to 'ye it's the idler pulley, it'll be fine, mines done it for the past 25k'.
Either way it's not normal and I would definitely be investigating sooner rather than later. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #457972 20th Nov 2017 7:34pm
good point Andy Thumbs Up ... - .- -.
Post #457975 20th Nov 2017 7:55pm
Paul thornton
Sounds like idler pulley to me.
My aircon pulley was squeeling in the mornings on first start up so I drowned it in wd40.... which then washed out the remainder of the grease from the bearing and it sounded just like that.
I managed to strip and regrease mine so you might get lucky.
Post #457976 20th Nov 2017 7:57pm
Paul thornton
Ps, I'd get it looked at asap regardless.
Post #457977 20th Nov 2017 7:59pm
OtleyDominic
Thank you, it is booked into the garage tomorrow. They believe it might be the fuel pump, but it is going in nevertheless Smile
Post #458020 21st Nov 2017 8:12am
OtleyDominic
Garage has checked it over and the idler pulleys seem to be the cause Smile
Post #458197 22nd Nov 2017 1:22pm
OtleyDominic
Idler pulleys replaced and the noise remains to some extent. In speaking with the garage apparently the 4.4 tdv8 is a noisy engine and many do have a light ticking?
Post #458453 24th Nov 2017 9:48pm
dingg1
Post #458467 24th Nov 2017 11:53pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
My td6 idle pulley fault was very louder and only was at idle. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #458481 25th Nov 2017 8:12am
OtleyDominic
The noise remains. After the lr specialist had it for three days, and noise remained, I took it to. LR main dealer who confirmed it didn't sound right. They found the oil overfilled by far, drained it to the right level and then checked codes but nothing explained the ticking. They think it could be related to wrong oil being used, compounded with a high number of dpf regens, putting crap in the oil! I only bought the car two weeks ago with a three month warranty. So it is back to garage tomorrow to see if they can fix it!
Post #458556 26th Nov 2017 10:41am
OtleyDominic
Youtube video of the noise this morning:
Suggestions i have received:
- Warn tappets
- Tappets from wrong oil grade
- Injector tick
- Noisy Lifter
- Warn Camshaft
- Cracked exhaust manifold
Post #458561 26th Nov 2017 12:06pm
