Home > Technical (L322) > 2011 coolant tank
Baltic Blue
Nino, I thought is was pretty clean until you posted your sparkling picture.
You win the prize . Mr. Green G reg 2.5VM Vogue Portofino red 1991- 1999
Post #457810 19th Nov 2017 11:07am
mpirie
nino_nino wrote:
mpirie, I had oil in my to from the leaking oil cooler. first time coolant was low enough to trigger the warning, float got stuck on the bottom and i had low coolant level on all the time. remedy was to clean the expansion tank, pictures here-
http://www.fullfatrr.com/forum/topic20913.html.
it is easy job.
nino
Link's not working, but I guess it would be easy enough to remove the tank and clean the insides.
Mike
Post #457833 19th Nov 2017 2:05pm
