![]() | Home > Technical (L322) > 2011 coolant tank |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Please can someone add a photo of the expansion tank on a 4.4 tdV8.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
here you go Mike..it does indeed look 'sucked' in.
Mike & Stan,
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
Stan,
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Here You go BB,
i have been clearly caught out |
Thanks Nino,
its un-canningly clean |
She likes it that way |
I still have the remnants of oil from the cooler problem in my header hence no picture.
At least they are all roughly the same distorted “sucked in “ shape.
mpirie, I had oil in my to from the leaking oil cooler. first time coolant was low enough to trigger the warning, float got stuck on the bottom and i had low coolant level on all the time. remedy was to clean the expansion tank, pictures here-
BB, we need to see yours yet. |
