![]() | Home > Technical (L405) > Does the AB remote heater heat up the engine? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35625 ![]() ![]() |
yes it does |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 413 ![]() ![]() |
But this morning it didn't do anything. I guess that after not using the car for 3 days it decides that the battery voltage is/will be too low if it carries on the auto cycle so decides to stop working.
Its an Engine pre-heater the cabin heating is an added benefit in a fullfat. |
Time for me to RTFM |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
Being pedantic, it's the coolant that is being heated. not the "engine". The main mechanical parts of engine, and the oil won't get anywhere near their operating temperature. |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
The inside of mine gets steamed up quite bad when using it! |
You�re lucky mines packed up after working just the once. Cant be arsed to take it to a dealer. |
WBSam Member Since: 04 Jan 2016 Location: aberdeen Posts: 3 ![]() ![]() ![]() |
plz where can i order oxygen sensor for DIESEL L405 2013? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3783 ![]() ![]() |
Main agent 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
