![]() | Home > Maintenance & Mods (L322) > One touch window closing |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
I recently fitted a new battery to find I had lost one touch open and close on all windows. Fixed the one touch open by depressing and holding the button down. But I can’t seem to reset the one touch close. Any ideas? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
do the same, hold the switch up ... ... - .- -.
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
This has worked for me. |
Pulling up the switch to reset has not worked. I had an Indy do the IID reset for the new battery install, could he have accidentally ticked a box to turn off the one touch window close? |
i wouldnt have thought so....so engine running and all doors closed and running the window down ,run window up and then pulling the window switch up for a while didnt work then. ... - .- -.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
Mine doesn't work on one window, rear offside, takes four button presses to open or close it. I've tried all the various fixes (like holding the button at the end of travel) but nothing seems to work. The Window doesn't seem to stick either but just keeps stopping at the same places every time. Geoff |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
My front passenger window does the same bloody thing.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
you may try putin something in thru the open window-like rolled up newspaper- so that window glass hits it going up and automatically retracts back down. it workt on my td5. |
Thank you ... will give that a go. |
I did exactly as above, but no success. All four windows have the same problem. All were okay before the new battery. |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 ![]() ![]() ![]() |
I have just removed my battery as a reset. As soon as that happens the auto up/down feature stops working.
Tried all the suggestions but still no joy, I guess it might have to be door card off and have a look |
thank you marcochezzi, I will give your very comprensive instructions a try in the morning. It is different to how I did it previously, so hoping for success. |
Unnecessary quote removed
