Home > Maintenance & Mods (L322) > One touch window closing |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1187 |
I followed your window fix after following someones other methods that did not work and your fix worked perfectly
18th Feb 2018 3:53pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
The key to it seems to be to close the window, let go of the switch then pull the switch again. I was making the mistake on closing the window and not releasing the switch for the second activation. Tom
8th Jul 2022 10:07am |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
Here I thought the feature came back all by itself. Maybe after pressing it so many times I got the right sequence in there after a day or two of fiddling. 2011 Vogue SE 4.4 TDV8 |
26th Jul 2022 12:02pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
On earlier models, the way to activate the auto window function is different to the late L322s.
26th Jul 2022 2:43pm |
