Home > Maintenance & Mods (L322) > Windscreen Wash or Antifreeze
supershuttle
I thought the pink stuff I filled my washer bottle with was Windscreen Wash I now think it was Antifreeze (label had washed of as I keep both outside). Embarassed
I could drain it or I could just put a squirt of detergent in and just use it in the normal way.
What do others think - apart from the fact that I'm losing it. Very Happy Geoff
Post #456764 10th Nov 2017 11:21am
Rob99
Oh dear........easily done.... Shocked
I thought anti-freeze would damage paintwork and I don't know what it would do to the plastic washer system and seals or any trims on the front of the car Big Cry
If it was me I would drain it, refill with clean water and then run quite a bit of it through to clear out the pipes and nozzles etc and then make sure you refill with correct stuff. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #456765 10th Nov 2017 11:32am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Rob99's is good advice Thumbs Up ,
If it were me I would also hose the car down straight away afterwards to dilute any residue that remains on the paintwork. Ive got power screen jets for the headlights and when they fire it goes everywhere.
Post #456768 10th Nov 2017 11:46am
Pink does sound like anti-freeze.
I also thought it was quite damaging stuff to paintwork, but not sure how bad - I certainly don't worry if I get it on my skin.
However, I'd be looking to drain it and dilute as best I could.
Post #456770 10th Nov 2017 11:46am
GGDR
...and just to add:
that stuff should be disposed of properly, maybe a local garage would take it rather than down the drain...
https://community.cartalk.com/t/disposing-unused-antifreeze/293/2
Good luck!
Greg Cheers, Greg
Post #456771 10th Nov 2017 11:49am
supershuttle
Thanks guys - neither does it clean the screen well Big Cry I wasn't going to drain as such just go for a drive and use the washers until there was none left then fill up with clean water - long drive I know Very Happy And when i get back I'll also rinse the car with the hose pipe just in case. Geoff
Post #456773 10th Nov 2017 11:55am
IIRC it's quite easy to remove the washer bottle entirely on an L322 - I'd definitely do that as likely far easier than burning out the washer motor or something dumb......
Post #456783 10th Nov 2017 12:37pm
at least your washer bottle wont freeze... Mr. Green ... - .- -.
Post #456785 10th Nov 2017 12:43pm
you could stick a hose pipe in the filling hole and flush out the antifreeze.. ... - .- -.
Post #456786 10th Nov 2017 12:45pm
supershuttle
Im using the Stan method, had to get some thin hose in order to insert far enough to be effective but flushing is in progress as I type. Too cold to be messing about removing bottles etc Very Happy Geoff
Post #456789 10th Nov 2017 1:11pm
supershuttle
Interesting effect while flushing, a small spurt is emanating from the headlamp washer as well. SWMBO said i needed something rigid to insert into the hole, was she trying to tell me something or just being helpful Whistle
 Geoff
Post #456790 10th Nov 2017 1:23pm
ah yes the hosepipe trick works wonders Shocked Laughing
[turned your pic round geoff] ... - .- -.
Post #456799 10th Nov 2017 2:24pm
supershuttle
And I edited as you've probably noticed - didn't want to look daft in the eyes of other forum members. Well no dafter than a man who puts anti-freeze in washer bottle. Very Happy Geoff
Post #456811 10th Nov 2017 3:27pm
If it makes you feel any better, my wife's best friend topped up her washer bottle at a petrol station using their watering can.
A kindly passer by advised her not to try starting the car as she was basically pouring water straight into the engine. She had just seen one cap when she opened the bonnet, so started filling that Rolling Eyes
Post #456814 10th Nov 2017 3:37pm
