Home > Maintenance & Mods (L322) > Windscreen Wash or Antifreeze |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
I thought the pink stuff I filled my washer bottle with was Windscreen Wash I now think it was Antifreeze (label had washed of as I keep both outside).
10th Nov 2017 11:21am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1419 |
Oh dear........easily done....
10th Nov 2017 11:32am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
Pink does sound like anti-freeze.
10th Nov 2017 11:46am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
...and just to add:
10th Nov 2017 11:49am |
Thanks guys - neither does it clean the screen well I wasn't going to drain as such just go for a drive and use the washers until there was none left then fill up with clean water - long drive I know And when i get back I'll also rinse the car with the hose pipe just in case. Geoff |
10th Nov 2017 11:55am |
IIRC it's quite easy to remove the washer bottle entirely on an L322 - I'd definitely do that as likely far easier than burning out the washer motor or something dumb...... |
10th Nov 2017 12:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35329 |
at least your washer bottle wont freeze... ... - .- -.
10th Nov 2017 12:43pm |
you could stick a hose pipe in the filling hole and flush out the antifreeze.. ... - .- -.
10th Nov 2017 12:45pm |
Im using the Stan method, had to get some thin hose in order to insert far enough to be effective but flushing is in progress as I type. Too cold to be messing about removing bottles etc Geoff |
10th Nov 2017 1:11pm |
Interesting effect while flushing, a small spurt is emanating from the headlamp washer as well. SWMBO said i needed something rigid to insert into the hole, was she trying to tell me something or just being helpful
10th Nov 2017 1:23pm |
ah yes the hosepipe trick works wonders
10th Nov 2017 2:24pm |
And I edited as you've probably noticed - didn't want to look daft in the eyes of other forum members. Well no dafter than a man who puts anti-freeze in washer bottle. Geoff |
10th Nov 2017 3:27pm |
If it makes you feel any better, my wife's best friend topped up her washer bottle at a petrol station using their watering can.
10th Nov 2017 3:37pm |
