![]() | Home > Maintenance & Mods (L322) > Windscreen Wash or Antifreeze |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
I thought the pink stuff I filled my washer bottle with was Windscreen Wash I now think it was Antifreeze (label had washed of as I keep both outside). |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1463 ![]() ![]() |
Oh dear........easily done.... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Pink does sound like anti-freeze.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
...and just to add:
Thanks guys - neither does it clean the screen well |
IIRC it's quite easy to remove the washer bottle entirely on an L322 - I'd definitely do that as likely far easier than burning out the washer motor or something dumb...... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
at least your washer bottle wont freeze... |
you could stick a hose pipe in the filling hole and flush out the antifreeze.. ... - .- -.
Im using the Stan method, had to get some thin hose in order to insert far enough to be effective but flushing is in progress as I type. Too cold to be messing about removing bottles etc |
Interesting effect while flushing, a small spurt is emanating from the headlamp washer as well. SWMBO said i needed something rigid to insert into the hole, was she trying to tell me something or just being helpful
ah yes the hosepipe trick works wonders |
And I edited as you've probably noticed - didn't want to look daft in the eyes of other forum members. Well no dafter than a man who puts anti-freeze in washer bottle. |
If it makes you feel any better, my wife's best friend topped up her washer bottle at a petrol station using their watering can.
