Home > Technical (L322) > Forward allert not avalible. Any thoughts |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
dirt on the sensors maybe? ... - .- -.
4th Nov 2017 10:11am |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 |
I was thinking the same Stan, any idea where the sensor is ?
4th Nov 2017 10:27am |
i knew you'd ask me that but i dont....some clever peeps will come along and tell us hopefully.. ... - .- -.
4th Nov 2017 10:41am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
The radar unit is behind bumper, below the right headlight.
^ told you so .. ... - .- -.
4th Nov 2017 10:43am |
I retro-fitted mine so should know! |
4th Nov 2017 10:46am |
GraemeS,
Forward alert not being enabled will be due to the ABS faults, not a fault with the radar unit.
4th Nov 2017 10:48am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I remember reading somewhere in the WM that the forward alert distance is adjustable, but can’t find it at the moment. G reg 2.5VM Vogue Portofino red 1991- 1999
4th Nov 2017 10:49am |
this might help Dave,
4th Nov 2017 10:52am |
Forward alert distance (actually time interval) is adjusted by holding the ACC +/- buttons whilst ACC is not enabled, but nothing to do with not being available. However perhaps Forward Alert needs to be re-enabled via the instrument cluster option if the ABS fault turned off the option. |
4th Nov 2017 10:54am |
