Home > Technical (L322) > Loud brake groan after brake job |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Nasty, it sounds like the metal disc guard is getting involved or the caliper is loose or pads are loose in the caliper.
1st Nov 2017 7:36am |
Kingstang Member Since: 01 Nov 2017 Location: New Jersey Posts: 11 |
They are aftermarket drilled/slotted/vented rotors, I de-greased them before installing. Anti-rattle clips are in, the set came with everything the factory would come with.....................This is happening on both sides, all I did was change the rotors and pads. I'm stumped!! |
1st Nov 2017 10:36pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
sounds like the pads and discs are still too new and not bedded in yet. I get a similar sound sometimes after I've washed the car ... it goes away after a few brakes. Have you taken it and done a bed in procedure ?
2nd Nov 2017 9:08am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
.Kingsteng,
2nd Nov 2017 9:41am |
Fellas,
3rd Nov 2017 3:31am |
I personally wouldn't worry about it. I just think its stiction from the new materials that still have to bed in properly. Keep us updated to see if it goes once the car has had a bit of a run. V8 or else ... |
3rd Nov 2017 8:46am |
Will do Fisha. |
3rd Nov 2017 1:44pm |
