![]() | Home > General > What Did You Do In Your Full Fat Today |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
502's look really good.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I spent £600.00 on B.B. today , having the oil changed in the gearbox, transfer box and both diffs.
vogue16 Member Since: 29 May 2015 Location: Angouleme Posts: 37 ![]() ![]() |
Hi guys
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Lovely looking motor, best of luck with it, I'll call in some morning for a look...... ![]() |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
spot of towing y.day , took my old terracan to the scrapyard , FF's really are great for towing |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
Two new front tyres fitted and tracking done and mot booked for friday. |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
Since I have owned my Full Fat Range Rover It's always needed a fog light bulb so this morning I finally got round to replacing it.
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
^^^ you're not getting an error on the dash with the LED fogs???
No errors on the screen the only thing which i didn't realise until it was dark is they flash on startup due to the bulb self test and perfectly normal with LED's. |
Interesting. Yes I get the startup flash with my LED light on the corner (the ones that sit below the turn signal in the headlamp)...but that doesn't bug me enough to stop using them. If you only get the startup flash with the fogs I might go ahead and get the LED lamp upgrades. 2014 FF Autobiography 5.0 SC
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Just got mine back from 4 days at the dealer. I had a new Evoque loaner in the meanwhile. I won't be buying one |
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 77 ![]() ![]() |
Pulled fuse 12 to attempt curing battery drain. Started great this morning after standing for three days - yippee!!
