Home > Camping, Caravanning and Holidays > Adle Heating System
Stormin
2003 Range Rover HSE Td6 Epsom Green
Adle Heating System
Anyone with a tintent that has the Alde heating system
Mine is making a noise, it sounds like the pump is catching on the bottom of the header tank.
The noise goes away once the fluid has warmed up.
Ive checked the level in the tank, its all correct. Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #455714 30th Oct 2017 7:56pm
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Probably a daft question, but has it always done it, or just started?
My last van had Alde hearing, and it was always noisey from new. The van I've got now has Trauma heating, and it's a lot quieter.
All I remember was that the fluid needs changing in the Alde every 5 years, I think !!
Post #455715 30th Oct 2017 8:42pm
Wogger
Should be heating not hearing,
Post #455717 30th Oct 2017 8:43pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Have you bled the radiators to see if there's any air blocks? 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #455722 30th Oct 2017 9:41pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Agreed, try and bleed the towel rail to see if you have air in the system.
Post #455723 30th Oct 2017 9:46pm
PaulB
Double post Rolling Eyes
Post #455724 30th Oct 2017 9:46pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
If you have a pump in the header tank then it can foul parts of the tank, try loosening the cap and tightening with the pump part in a slightly different rotation.
I have heard of people fitting two rubber washers to lift the pump slightly.
The fluid in British vans only has a life of two years and should be replaced by five year fluid G13 spec.
Dealers are charging between �200 to �250 to change Alde �160 but you have to take the van to them.
I just bought 5litres of G13 for �14.99 and �10 for a manual pump to change my own.
Ian
Post #455748 31st Oct 2017 9:19am
Stormin
Thanks everyone
The van is a 2016 so not old enough for fluid change, ive even sent the pump back to alde who say its working correctly
Tried the cap idea with no joy, but haven't tried two seals.
Its going in next week for warranty work so ill see what they say Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #455770 31st Oct 2017 2:25pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Wallace Caravans Kirkcaldy charged me �300 Ian ! To change mine! Needless to say we haven�t been back!! 2014 vogue se
Post #455779 31st Oct 2017 4:53pm
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
G13 5litre concentrate now �11.69 ecp
Post #455796 31st Oct 2017 8:05pm
n1cktdv8
Wiggle it. The base of the pump can often move and foul it's surroundings. When I had mine I used to pull it up a little and hold it until it settled. Was always fine after a few mins and only happened in winter. Is this where I put the car details and a bit about myself ?........
Post #455823 1st Nov 2017 10:10am
mzplcg
Yes, had this on ours. The pump can be moved in the rubber washer. Loosen the cap and lift the pump slightly whilst re-tightening the cap.
Post #455825 1st Nov 2017 10:39am
