![]() | Home > Camping, Caravanning and Holidays > Adle Heating System |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Probably a daft question, but has it always done it, or just started?
Should be heating not hearing, |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Have you bled the radiators to see if there's any air blocks? 2019 L405 SDV8 Autobiography
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Agreed, try and bleed the towel rail to see if you have air in the system. |
Double post |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
If you have a pump in the header tank then it can foul parts of the tank, try loosening the cap and tightening with the pump part in a slightly different rotation.
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Thanks everyone
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 754 ![]() ![]() ![]() |
Wallace Caravans Kirkcaldy charged me �300 Ian ! To change mine! Needless to say we haven�t been back!! 2014 vogue se |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
G13 5litre concentrate now �11.69 ecp |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Wiggle it. The base of the pump can often move and foul it's surroundings. When I had mine I used to pull it up a little and hold it until it settled. Was always fine after a few mins and only happened in winter. Is this where I put the car details and a bit about myself ?........ |
Yes, had this on ours. The pump can be moved in the rubber washer. Loosen the cap and lift the pump slightly whilst re-tightening the cap. |
