![]() | Home > General > Help! TD6 won't rev past 3k. |
Two thoughts on this, the TD6 is of course a Commone Rail engine and if it was the high presure pump it would not work at all and going back through treads on this and other sites over the past year or so a failing low presure pump is a much more Commone problem than I realised . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
I think low pressure pump is at fault, had a friend with the same symptoms and the replacement cured it... |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
kriswilson,
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
I don't think it was one that could show live data... It was a snap on one and all we did was clear all faults, take it for a 20 minute drive of A roads and some motorway then re-scan for the codes. It was the same two that appeared...
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Almost certainly NOT this but my Range Rover was delivered in some sort of delivery mode where it wouldn't go over 30 mph. So much for the PDI. it just needed plugging in to the dealer's laptop to allow the car to be driven normally. |
Possibly a faulty fuel rail sensor |
Ok so the battery was replaced along with the fuel filter. Car seemed to be running fine until the road back up Glasgow this past weekend and it started this 3k rpm limit again whilst trying to overtake.
powderdog Member Since: 29 Nov 2010 Location: Lanarkshire Posts: 3 ![]() ![]() ![]() |
This sounds like the same problem I had. Turned out to be exactly what you suapect ie low pressure fuel pump!
paultuk Member Since: 04 Jun 2010 Location: Between Scotland and France Posts: 15 ![]() ![]() |
My TD6 had the same issue. Fuel starvation issue at high revs.
Help!! Had both the rear wheels off and don't see any pump.. Both arch liners are out also....
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Your pump has fell off.
Got it! Finally.
This might help, number 4 is what you should be looking for
That would of helped no end and saved alot of time |
