Home > General > Help! TD6 won't rev past 3k.
Page 3 of 3 <123
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Come on then, the suspense is intense ... is it a Thumbs Up or a Evil or Very Mad 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #47817 27th Jan 2011 2:24pm
kriswilson
Scotland 2007 Range Rover Vogue SE Supercharged Java Black
Well it seems to be reving freely now...
On the quick drive home last night it kicked down as before and reved through until 4.5k rpm. This weekend will tell as its normally when cruising on the motorway that it struggles to go from 65mph to 75mph...
Will report back.
Thanks for all the help !!
Post #47855 27th Jan 2011 5:51pm
A sticking EGR valve or a split in the turbo pipe could be causing the fault
Post #47859 27th Jan 2011 6:01pm
Now if you had my EcoDrive OBD system you could read the inlet manifold pressure on the Sat Nav Whistle
Post #47865 27th Jan 2011 6:13pm
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
Or on auto logic computer and a landrover workshop Thumbs Up 2011 4.4tdv8 vogue black with black
2005 autobiography supercharged in Auckland blue!
2005 supercharged now sold
2011evoque now sold
2007 tdv8 vogue se gone but not forgotten
rrsport 2.7 hse gone
4.4 autobiography 2004
Post #47888 27th Jan 2011 9:17pm
kriswilson
Think it's best I try and get a hold of an OBD scanner and the connections to run it through the laptop.
Can anyone recommend the cables and software required?
Not sure the snap on code reader I used before was giving me the correct information
Post #47894 27th Jan 2011 9:35pm
Page 3 of 3 <123
