Home > General > Help! TD6 won't rev past 3k. |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 |
I had similar on my wife Turbo mundeo.
10th Jan 2011 7:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
sounds like the fuel pump or filter.. |
10th Jan 2011 7:08pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Air flow meter?
10th Jan 2011 7:42pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
My dad had a similar problem with his disco. He changed a vacuum line and valve recommended from another forum. Tuned out the garage had washed his air filter (thinking it was a reusable) when it wasn't it started to brake up and was blocking the inlet over certain revs.
10th Jan 2011 8:39pm |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 |
Thanks for all the help so far.....
10th Jan 2011 9:09pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I had a 530d with a similar problem and it was the fuel pump, I would think this might relate to your fault codes too. Range Rover-less at the moment - Pining! |
10th Jan 2011 9:14pm |
Can anyone help with the part numbers for the Low Pressure Fuel Pump and the Filter that goes with it??
10th Jan 2011 10:15pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
how olds your fuel filter? sake of a tenner and 5 min work try that first. 2004 black Vogue TD6 |
10th Jan 2011 10:23pm |
I'm guessing it must be the original. Went back through the folder of reciepts tonight and cant see any evidence of the fuel filter being replaced.
10th Jan 2011 10:27pm |
http://www.britishparts.co.uk/.sc/ms/dd/Ra...TER-DIESEL 2004 black Vogue TD6 |
10th Jan 2011 10:37pm |
good diagnostics scarey... 2004 black Vogue TD6 |
10th Jan 2011 10:40pm |
Ordered. Will let you know once fitted.
10th Jan 2011 10:45pm |
Do you have AA cover? If you had the 'breakdown repair insurance' they would cover things like the fuel pump, got mine replaced by them on the 530d, only had to pay the £25 excess! Range Rover-less at the moment - Pining! |
10th Jan 2011 11:05pm |
well mine had full land rover service history and the fuel filter looked like it hadn't been changed for years. does it look new? 2004 black Vogue TD6 |
10th Jan 2011 11:08pm |
