Home > In Car Electronics (L322) > My Reverse Camera Install |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
Don't you have the images on your computer? Ron B. VK2OTC
4th Oct 2017 3:25am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
4th Oct 2017 7:18am |
4th Oct 2017 7:28am |
Thanks miggit.
4th Oct 2017 11:00am |
Your camera might not be as wider angle as the one that I used, it was a 170 degree camera.... you might be able to pack the outside edge of the camera / light assy to angle it down a bit more
4th Oct 2017 5:10pm |
Thanks miggit. I never thought about depth perception with a bumper mount.
8th Oct 2017 9:11pm |
The one I used was 170 x 120 deg.
9th Oct 2017 1:34am |
Yes, that's the bumper.
9th Oct 2017 5:28am |
If you tow it is worth its' weight in gold, with the camera in that position it is very hard to get the car / trailer in the wrong place.... and being aftermarket, I found that the camera worked perfectly, long after the PDC had gone up the pictures... In fact to be honest I never bothered with the reversing sensors after the camera was fitted, I'd rather trust that which I could see, rather than temperamental bleeper!!
10th Oct 2017 11:24am |
standupking36 Member Since: 30 Jun 2017 Location: lincolnshire Posts: 76 |
wish i could see ye pictures to give me a better idea on whats being described, also will it work on a touch screen unit please?
10th Oct 2017 8:24pm |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
I should have got round to trying my "hooking up camera", as it doesn't fit anywhere near as well on the FFRR as it did on the Disco or 110. The tailgate slopes too much, so if I set this up I think I'll have to fabricate some extension piece to, perhaps, clip into a roof rail mounting. I've used this technique for years and the camera sticking over the back of the Landie, pointing down on a bendy but stiff gooseneck really is quite quick to rig and easy to use.
11th Oct 2017 12:06pm |
The problem with your setup is, it is looking directly down on the tow hitch, while you will get perfect dept, you're not getting much of the trailer until the last few feet... too late to adjust your direction to line anything up.
11th Oct 2017 2:27pm |
I will admit to being pretty hopeless at reversing a trailer, and only ever have had 2 or 3 sessions a year with a LR, when moving boats to be launched. (the little trailer in the earlier pic is just a rubbish trailer that goes on the smaller car, where I have some hope of seeing it).
12th Oct 2017 7:07pm |
I never really posted a lot of pictures for the reversing camera as it would have just been repeating everything that had been posted by others.. the only 2 that are possibly different are posted above . However as most threads have been stuffed by photobucket money grabbing 's I realise that there are a few puzzled peeps out there... ask and I will do my best to provide... But please bear in mind that I no longer have an L322... but I can lay my gribby mits on a converted pals car if needed!!
13th Oct 2017 11:57am |
