![]() | Home > Maintenance & Mods (L322) > Changing the engine oil - to use a flushing additive or not? |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Hello all,
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
They can be quite good and we offer them to customers at my work and they seem to go down well.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
Unless you have a particular problem with sludge or blocked oil ways etc, why would you use this? |
In the boat there is no sump plug, using it made it easier to vacuum out, I wasn't too fussed about whether or not there was a long term issue on it because I sucked it all out.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I've always used a couple of bottles of Forte Advanced Engine Flush in mine but I was a bit concerned that some remained in the engine after draining and then mixed with the new oil diluting it so last time I chucked in some cheap fully synthetic with the view of doing another oil only change but I'm still on the cheap synthetic
Thanks Holiday Chicken.
Do you have any rattles or taps ?
No rattles or taps but the engine does Hummm loudly, like tha fan is running super loud on starting idle
mine does that from time to time, i wouldn't worry about a humm, you could try reading the codes but as long as you are not using any oil or water then it could be to do with the HEVAC.
More like a fan hum from where the fan is.
The fatty tends to be more hole than bucket, at least mine was.
