Home > Maintenance & Mods (L322) > Changing the engine oil - to use a flushing additive or not? |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Hello all,
4th Oct 2017 12:16pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
They can be quite good and we offer them to customers at my work and they seem to go down well.
4th Oct 2017 1:51pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Unless you have a particular problem with sludge or blocked oil ways etc, why would you use this? |
4th Oct 2017 2:31pm |
In the boat there is no sump plug, using it made it easier to vacuum out, I wasn't too fussed about whether or not there was a long term issue on it because I sucked it all out.
4th Oct 2017 7:07pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I've always used a couple of bottles of Forte Advanced Engine Flush in mine but I was a bit concerned that some remained in the engine after draining and then mixed with the new oil diluting it so last time I chucked in some cheap fully synthetic with the view of doing another oil only change but I'm still on the cheap synthetic
4th Oct 2017 7:44pm |
Thanks Holiday Chicken.
5th Oct 2017 9:00am |
Do you have any rattles or taps ?
5th Oct 2017 6:46pm |
No rattles or taps but the engine does Hummm loudly, like tha fan is running super loud on starting idle
5th Oct 2017 6:52pm |
mine does that from time to time, i wouldn't worry about a humm, you could try reading the codes but as long as you are not using any oil or water then it could be to do with the HEVAC.
5th Oct 2017 8:06pm |
More like a fan hum from where the fan is.
5th Oct 2017 8:51pm |
The fatty tends to be more hole than bucket, at least mine was.
6th Oct 2017 1:53am |
