![]() | Home > Technical (L322) > Range Rover L322 2005 height Calibration |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Welcome to the forum.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 ![]() ![]() |
err, it is in the correct section... ... - .- -.
Stan, it appears Martin beat you to it:
i'm slacking |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Here, the heights for 22" if it helps.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 ![]() ![]() |
But measurements for calibration are always taken from the hub centre (IID/AllComms), and therefore the same for any wheel/tyre combination |
Joe90,
i cant see why pre 2006 FF's would be any different to the newer ones..
I cannot remember which named tool they were using (but was range rover specialist garage), but i was there when they needed to input numbers and on the earlier cars on there tool it needed to be measured from the bottom wheel. which is why i had the sheet above.
This is causing confusion.
i thought the same Tim |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Hi johnmaambo and welcome to the forum.
@ johnmaambo
Hi Guys,
