![]() | Home > Technical (L322) > Range Rover L322 2005 height Calibration |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Welcome to the forum.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
err, it is in the correct section... ... - .- -.
Stan, it appears Martin beat you to it:
i'm slacking |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Here, the heights for 22" if it helps.
Link to higher Res image so easyer to read. https://imgur.com/a/Yty74 I had an issue with garage not in putting the correct values when setting mine up ages ago.. (car looked like was in offroad mode all the time) but as said above configuration is normally setup on 20" settings use the images for the numbers and just select wheel size as 20" and in put the numbers above.. once done check the heights with tape measure. 2003 Range Rover 4.4 Litre V8 - Adriatic blue 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
But measurements for calibration are always taken from the hub centre (IID/AllComms), and therefore the same for any wheel/tyre combination |
Joe90,
i cant see why pre 2006 FF's would be any different to the newer ones..
Y. O. L. O. . |
I cannot remember which named tool they were using (but was range rover specialist garage), but i was there when they needed to input numbers and on the earlier cars on there tool it needed to be measured from the bottom wheel. which is why i had the sheet above.
This is causing confusion.
i thought the same Tim |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Hi johnmaambo and welcome to the forum.
@ johnmaambo
Hi Guys,
