Home > Maintenance & Mods (L322) > Shall I bin the scissor jack? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Might be handy as a backup, second point of support etc. .
24th Sep 2017 10:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35270 |
what Tim says ... - .- -.
25th Sep 2017 6:11am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
Can/would someone be able to measure the diameter and thickness of (what I assume is a large O-ring)the thing that holds the jack in place in the L322?
25th Sep 2017 6:16am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Use the scissor jack on level ground ensuring that base of jack is directly under jacking point. Do not solely rely on the jack if having to work under car (same goes for any jack really).
25th Sep 2017 6:29am |
Andy-B Member Since: 23 Mar 2017 Location: Todmorden Posts: 21 |
My personal experience is that it is made of cheese and use only with great caution.
25th Sep 2017 8:04am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1385 |
I've got a sprinter bottle jack in my boot. The scissor jack had never been used so I've just put it in the garage so I can stick it back in the Westie when I eventually sell it on. 2017 4.4 SDV8 Autobiography
25th Sep 2017 1:12pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
Me too ^^ |
25th Sep 2017 1:17pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
P38 do you mean the strap ting that holds the scissor jack in place normally? Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
The threads on my Land Rover scissor jack stripped the first time I used it. Chuck in the skip. |
25th Sep 2017 1:36pm |
Yes, Greg. I've not seen what should be there. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
25th Sep 2017 2:02pm |
P38 does this image help?
25th Sep 2017 2:49pm |
a bungee cord will keep it in place... ... - .- -.
25th Sep 2017 2:56pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
I gave my to the neighbor who has golf. he likes it for the extra lift it gives. that jack was not properly designed for the 3t car it is intended for but it works OK on a 1.2t. this is what I use empty space for.
25th Sep 2017 3:02pm |
It does indeed. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
25th Sep 2017 10:34pm |
