Home > Maintenance & Mods (L322) > Shall I bin the scissor jack?
GGDR
Just picked up a Sprinter Bottle Jack. Thumbs Up
I've read all the posts on the scissor jack, shall I just bin it?
Maybe binning the scissor will offset some weight!
Those little bottle jacks weigh a fair bit huh?
. Cheers, Greg
Post #451960 24th Sep 2017 10:06pm
Might be handy as a backup, second point of support etc. .
Post #451967 24th Sep 2017 11:16pm
what Tim says Thumbs Up ... - .- -.
Post #451979 25th Sep 2017 7:11am
p38arover
Australia
Can/would someone be able to measure the diameter and thickness of (what I assume is a large O-ring)the thing that holds the jack in place in the L322?
Mine rattles around.
It might be cheaper to buy a rubber ring than trying to get one from LR (if they even carry it as a spare in Oz). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451980 25th Sep 2017 7:16am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Use the scissor jack on level ground ensuring that base of jack is directly under jacking point. Do not solely rely on the jack if having to work under car (same goes for any jack really).
When at home make use of axle stands. If taking a wheel off to maintain brakes etc. shove wheel under car as added protection.
If the jack base and jacking point move out of line then scissor jack has a tendency to collapse. (chock wheels, still in contact with ground, to prevent fore/aft movement). Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #451981 25th Sep 2017 7:29am
Andy-B
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
My personal experience is that it is made of cheese and use only with great caution.
Mine collapsed/twisted and dropped the car while on the very flat and level surface of my garage. Shocked
Andy 4.4V8 Petrol Vogue 2002
Post #451995 25th Sep 2017 9:04am
Rob99
I've got a sprinter bottle jack in my boot. The scissor jack had never been used so I've just put it in the garage so I can stick it back in the Westie when I eventually sell it on. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #452028 25th Sep 2017 2:12pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Me too ^^
Post #452030 25th Sep 2017 2:17pm
GGDR
Mine rattles around. It might be cheaper to buy a rubber ring than trying to get one from LR (if they even carry it as a spare in Oz).
P38 do you mean the strap ting that holds the scissor jack in place normally?
Greg Cheers, Greg
Post #452033 25th Sep 2017 2:17pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
The threads on my Land Rover scissor jack stripped the first time I used it. Chuck in the skip.
Post #452036 25th Sep 2017 2:36pm
p38arover
Australia
Greg
Yes, Greg. I've not seen what should be there. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #452045 25th Sep 2017 3:02pm
GGDR
P38 does this image help?
(not mine, borrowed from another thread) Cheers, Greg
Post #452051 25th Sep 2017 3:49pm
a bungee cord will keep it in place... ... - .- -.
Post #452053 25th Sep 2017 3:56pm
nino_nino
I gave my to the neighbor who has golf. he likes it for the extra lift it gives. that jack was not properly designed for the 3t car it is intended for but it works OK on a 1.2t. this is what I use empty space for.
Post #452057 25th Sep 2017 4:02pm
p38arover
Australia
It does indeed. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #452120 25th Sep 2017 11:34pm
