Home > Maintenance & Mods (L322) > Deployable side steps
Page 1 of 3 123>
j_rov
Calling those that have the deployable side steps on their fatty...
Are they good, worth it, useful etc?
Cheers __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #450493 10th Sep 2017 8:43pm
GGDR
Don't hesitate. Best RR gadget ever!
. Cheers, Greg
Post #450494 10th Sep 2017 8:48pm
Yep Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #450495 10th Sep 2017 8:49pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Much easier to get in and out of the car with them.
Post #450500 10th Sep 2017 9:20pm
Fantastic! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #450505 10th Sep 2017 10:31pm
Agree with above comments, but mine (at 5 years old) need lubing every 6 to 8 weeks or they stick and misbehave. I've found a cool gadget attracts great derision if it fails in public... Mike - MPx
Post #450506 10th Sep 2017 10:31pm
millerj90
What method and lube do you use?
Post #450507 10th Sep 2017 11:07pm
Currently use 3in1 High Performance Lubricant with PTFE. The steps have a good safety feature that they return (in or out) if they meet much resistance on their travel. The offside step suddenly stayed out during a trip to north Cornwall on a Sunday and that 3in1 stuff was the best I could find in the only available open corner shop. I think its better than WD40. Deployed steps are not a useful feature on Cornish lanes and I was a bit worried about damage if I needed to take refuge in a gateway etc
I spray each side of each pivot rod where it goes through the brackets (that's about 16 places per end), and importantly the drive shaft from the motor assembly at the front. If I've left it long enough that a step is misbehaving then I usually have to manually assist (push or pull) to get the step to cycle properly. Once its working I spray again and cycle it a few times. As I said, it should last a few weeks then - indeed I last did it on 24th July so its probably time again now. Its possible to hear it labouring when it needs doing, but I've not yet managed to pinpoint exactly where the noise/problem is coming from so I tend to do the whole lot. I got the car in Feb. The steps were lubed at the dealers in April, and I've done it three times since then. Mike - MPx
Post #450522 11th Sep 2017 7:37am
millerj90
Brilliant feed back, many thanks.
Post #450539 11th Sep 2017 12:27pm
j_rov
So they seem like a good mod then...
Only lasting 5 years before needing very regular maintenance is a bit of a bad point though.
Are they strong enough to be used to stand on when washing the car or reaching to the roof etc? __
Land Rover History:
1976 Series 3 2.25
Post #450545 11th Sep 2017 1:18pm
millerj90
j_rov
They have a "lock out" setting that allows you to reach the roof.
Post #450554 11th Sep 2017 2:02pm
j_rov
Millerj90, thanks, but are they strong feeling? I had steps on my discovery 2 and they felt a bit flimsy.. Ok for a single foot into the car, but standing with both feet reaching up was not great (granted they were 10 years old...). __
Land Rover History:
1976 Series 3 2.25
Post #450567 11th Sep 2017 3:52pm
millerj90
j_rov
They feel strong enough to me. I've been standing on them to get to the roof and I'm no Size Zero!
Post #450570 11th Sep 2017 3:54pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I think these are very cool but can they take any stick ? already had my FF upto the sills deep in it so will these take a bash ?
Post #450630 11th Sep 2017 9:05pm
The steps themselves are strong enough bits of kit, I'd say just as robust as the fixed steps I had on my last SC. But they have a motor each side and loads of moving parts. I'm not sure how the motor would react to wading or wallowing in mud. I would think that hitting a rock in the wrong place could also cause some issues. Absolutely no prob driving across fields and the like, but not ideal for proper trials stuff. Mike - MPx
Post #450658 11th Sep 2017 10:45pm
Page 1 of 3 123>
