Home > Technical (L405) > Spare wheel lifters
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Spare wheel lifters
Help,
On t'internet, the following both come up as suitable for the L405:
LR085460 and LR057367 - does one supersede the other? It doesn't help that some adverts say "Range Rover L322 2013 onwards" which isn't right. Photos show essentially the same kit...... 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #448304 18th Aug 2017 4:32pm
Triarii
After much ping-ponging the seller agreed that post 2012 meant L405 RR despite what they kept saying so now have a LR057367. 17 MY Corris Grey 4.4 VAB
Post #449089 25th Aug 2017 6:04pm
1strangerover2017
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Is this suited for a tyre saving spare or a full size spare?
Post #449091 25th Aug 2017 6:12pm
Triarii
Both I guess. I'm getting a full size which will be a pig to lift out. 17 MY Corris Grey 4.4 VAB
Post #449093 25th Aug 2017 6:27pm
I think they come as standard witth a full size spare, so I guess that LR deem the space saver light enough to man handle, but the bigger wheels need a lift......
Post #449107 25th Aug 2017 8:08pm
pld118
Had to lift a 22" tyre into L405 boot this evening... Je*u*... and that's without a wheel attached!
Post #449108 25th Aug 2017 8:12pm
1strangerover2017
Wanted a full size spare when I ordered my vehicle, my17 4.4ab Lwb, but they said not an option (but the same vehicle I think in SV version was full size spare as standard!!), so have purchased one separately at significantly more than the factory order cost of approx £200!, hence needing to know, but will need to check if there is a lift system in, I had ordered 22" turbines, so presumably the space saver spare will be a 22". Wait for the sunlight in the morning for the search to begin!
Post #449110 25th Aug 2017 8:20pm
It won't be a 22 - but it will be the same overall diameter with the tyre on
Post #449142 26th Aug 2017 10:31am
1strangerover2017
No lift system (straps) for a space saver, just looks like the jack at the back and the wheel nut wrench.
There is a big piece of polystyrene that the space saver sits on, it makes up the width difference I think between the space saver and the full size spare, anyone who had the full size spare from new have any polystyrene ?
I NEED a lift, took two of us to put in the spare full size wheel in the back, under the board - I now understand why the Range Rover weighs so much with 4 of these on every vehicle Exclamation
Post #449203 26th Aug 2017 7:27pm
No polystyrene with a full size spare
Post #449206 26th Aug 2017 7:50pm
1strangerover2017
Hi Alaister,
Thank you, do you have something under the alloy to reduce chance of shorting any cables, Also does your board sit flat with the full size alloy?, mine seem to be slightly raised about half a centremeter or have I done something wrong?
Post #449210 26th Aug 2017 8:38pm
Tyre is against the metal floor, but as the whole thing is clamped in place and doesn't move, I don't really see why any cables are at risk.
The tyre is about level with the plastic blocks either side.
The highest point is the circular screw adjustable clamp thingy in the middle.
The boot floor should be flat - it's designed for a full size spare, they just put some polystyrene in there to pad out for the narrower space saver, so once that's removed, it should fit.
Is your centre clamp thing adjusted properly ? Is the floor flat if you remove that ?
Post #449229 27th Aug 2017 8:02am
1strangerover2017
Thank you Alistair Bow down Bow down Bow down
I took out the centre clamp and the rear board went flat even with the full size wheel in, so then checked everything again and realised the wheel was slightly off centre, realigned and checked the board still went flat, then replaced centre clamp and hey presto all systems go!!! Very Happy Very Happy
I have put a cloth beneath the wheel and the base as there are a few cables, think it looks like the battery located under the wheel, just to reduce any risk of shorting with the alloy wheel.
I have measured the space saver and the full size they are both 30" in diameter (alloy and tyre), BUT my full size alloy wheels are 23" in diameter (turbines) , they are meant to be 22" ........ the tyres are 22" .... what is going on ?!?!?, I have checked all the wheels on the car and they are all 23" everyone else must be the same?
Great weather and another challenged resolved Thumbs Up Thumbs Up
Post #449238 27th Aug 2017 11:45am
Rob99
Wheel diameters are measured on the part that the tyre bead sits on, not the outer lip, so they will appear too big if you measure the actual alloy. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #449278 27th Aug 2017 9:26pm
1strangerover2017
Thank you , Thumbs Up , learn something new every day!
Post #449741 2nd Sep 2017 7:51am
