Home > Technical (L405) > Spare wheel lifters |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 186 |
After much ping-ponging the seller agreed that post 2012 meant L405 RR despite what they kept saying so now have a LR057367. 17 MY Corris Grey 4.4 VAB
25th Aug 2017 6:04pm |
1strangerover2017 Member Since: 11 Jun 2017 Location: Cambridgeshire Posts: 76 |
Is this suited for a tyre saving spare or a full size spare? |
25th Aug 2017 6:12pm |
Both I guess. I'm getting a full size which will be a pig to lift out. 17 MY Corris Grey 4.4 VAB
25th Aug 2017 6:27pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7954 |
I think they come as standard witth a full size spare, so I guess that LR deem the space saver light enough to man handle, but the bigger wheels need a lift...... |
25th Aug 2017 8:08pm |
Had to lift a 22" tyre into L405 boot this evening... Je*u*... and that's without a wheel attached! |
25th Aug 2017 8:12pm |
Wanted a full size spare when I ordered my vehicle, my17 4.4ab Lwb, but they said not an option (but the same vehicle I think in SV version was full size spare as standard!!), so have purchased one separately at significantly more than the factory order cost of approx £200!, hence needing to know, but will need to check if there is a lift system in, I had ordered 22" turbines, so presumably the space saver spare will be a 22". Wait for the sunlight in the morning for the search to begin! |
25th Aug 2017 8:20pm |
It won't be a 22 - but it will be the same overall diameter with the tyre on |
26th Aug 2017 10:31am |
No lift system (straps) for a space saver, just looks like the jack at the back and the wheel nut wrench.
26th Aug 2017 7:27pm |
No polystyrene with a full size spare |
26th Aug 2017 7:50pm |
Hi Alaister,
26th Aug 2017 8:38pm |
Tyre is against the metal floor, but as the whole thing is clamped in place and doesn't move, I don't really see why any cables are at risk.
27th Aug 2017 8:02am |
Thank you Alistair
27th Aug 2017 11:45am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1445 |
Wheel diameters are measured on the part that the tyre bead sits on, not the outer lip, so they will appear too big if you measure the actual alloy. 2021 D350 Fifty Edition - Carpathian Grey
27th Aug 2017 9:26pm |
Thank you , , learn something new every day! |
2nd Sep 2017 7:51am |
