Home > Technical (L322) > Suspension leak, one corner dropping. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
you could raise to off road and check for leaks with copious amounts of soapy water. ... - .- -.
30th Jun 2017 12:47pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Thanks Stan, but tried that already and no joy, couldn't hear or see anything but might try jacking it to fully extend the strut and have another go, thanks. |
30th Jun 2017 1:30pm |
Finally got around to jacking the FF to look for a suspected leak.
7th Jul 2017 2:47pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Can you disable the EAS with your "reader" ? ( you can with the IIDTool ) If you can get car to normal height then disable. If height drops at LF then you must have a leak in that area (bag/pipes/control valve). Otherwise could be a height sensor. .
7th Jul 2017 9:19pm |
Thanks for that Joe, but it's operating correctly without any warnings or faults showing, it will properly cycle to and from normal ride height, it's just dropping over night or a long period, but seems to the the front left in particular and I'm assuming the rest are following due to the self leveling, once started it will immediately rise to normal and level position.
8th Jul 2017 10:38am |
Yes, by disabling the ECU won't do any self levelling or other stuff, so everything should stay as it was, all control valves closed etc. This isolates each corner. If a corner drops like this, then air is the problem at that corner, if it drops all round, it is a central air issue e.g. at the reservoir. If it stays up, then the problem more likely to be sensors / ECU.
8th Jul 2017 11:15am |
Cheers for that Joe, I might try leaving the door open when I get home tonight and see what it's like in the morning. |
8th Jul 2017 12:37pm |
Apologies for the absence from this thread and the forum, the RR has been on the back burner for a while to deal with more pressing issues, non vehicular but just as much trouble......
14th Aug 2017 3:38pm |
First valve block to have a look at is the one behind the Front Right Wheelarch liner, next to the mudguard, to check for leaks and condition. This is the first point that controls air to that corner. Then to the reservoir valve block. Shouldn't need to check any further back than that.
14th Aug 2017 5:20pm |
Thanks again Joe, it certainly makes sense to start at the front and work back since the problem certainly seems to be isolated to the LF corner.
16th Aug 2017 10:58am |
have you tried looking for leaks with it in extended off road mode? ... - .- -.
16th Aug 2017 11:26am |
Hi Stan, yes, tries that, extended mode and also jacked the corner to fully extend the strut and still couldn't see anything, or more correctly couldn't see anything on the parts that were visible.
16th Aug 2017 11:52am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
There is a spot where the supply pipe rubs on the bodywork and can rub through.
16th Aug 2017 12:01pm |
Thank you sir........
16th Aug 2017 12:09pm |
