![]() | Home > Technical (L322) > Suspension leak, one corner dropping. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
you could raise to off road and check for leaks with copious amounts of soapy water. ... - .- -.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Thanks Stan, but tried that already and no joy, couldn't hear or see anything but might try jacking it to fully extend the strut and have another go, thanks. |
Finally got around to jacking the FF to look for a suspected leak.
Can you disable the EAS with your "reader" ? ( you can with the IIDTool ) If you can get car to normal height then disable. If height drops at LF then you must have a leak in that area (bag/pipes/control valve). Otherwise could be a height sensor. .
Thanks for that Joe, but it's operating correctly without any warnings or faults showing, it will properly cycle to and from normal ride height, it's just dropping over night or a long period, but seems to the the front left in particular and I'm assuming the rest are following due to the self leveling, once started it will immediately rise to normal and level position.
Yes, by disabling the ECU won't do any self levelling or other stuff, so everything should stay as it was, all control valves closed etc. This isolates each corner. If a corner drops like this, then air is the problem at that corner, if it drops all round, it is a central air issue e.g. at the reservoir. If it stays up, then the problem more likely to be sensors / ECU.
Cheers for that Joe, I might try leaving the door open when I get home tonight and see what it's like in the morning. |
Apologies for the absence from this thread and the forum, the RR has been on the back burner for a while to deal with more pressing issues, non vehicular but just as much trouble...... |
First valve block to have a look at is the one behind the Front Right Wheelarch liner, next to the mudguard, to check for leaks and condition. This is the first point that controls air to that corner. Then to the reservoir valve block. Shouldn't need to check any further back than that.
Thanks again Joe, it certainly makes sense to start at the front and work back since the problem certainly seems to be isolated to the LF corner.
have you tried looking for leaks with it in extended off road mode? ... - .- -.
Hi Stan, yes, tries that, extended mode and also jacked the corner to fully extend the strut and still couldn't see anything, or more correctly couldn't see anything on the parts that were visible.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
There is a spot where the supply pipe rubs on the bodywork and can rub through.
Thank you sir........ |
