![]() | Home > Technical (L322) > 4.4 TDV8 Cracked air intake manifold |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
how did you know?? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3819 ![]() ![]() ![]() |
The air changeover valve and the 4 short rubber hoses have both been modified and replaced with an improved design so these should be permanent fixes.
Mikeyp,
I have just found this alternative diagram showing both RHand and LHand inlet manifolds.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
There will be a fair bit to strip to get this off, the intake manifold and rubbers hoses for starters. Those bolts for the manifold will need to be torqued down in order too. As I said originally not impossible but a big job. BB is right, if you are not confident don't start it. Find a good local garage and get them to do it, as before it is nut and bolt work, but better safe than sorry if you're not confident.
Stu,
I agree 100% with you Mike, a bodge job is not an option! The only type of job is 100% correct first time. I would get the prices for all relevant parts and quotes for labour then make my mind up, but if you are confident and got all the tools this is not beyond you.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Has the OP solved his problem?Was the inlet/camcover broken?What material is it made off?
Checked the inlet/camcover.....seems like some composite material(plastic),not metal! 2012 TDV8 Vogue SE 4.4 |
I suppose that the original design of hose allowed for a bit of vibration, being a bit more flexible, but the newer hoses are really pretty rigid.
Mikeyp/ sekrap,
8nil Member Since: 15 Jul 2018 Location: Surrey Posts: 1 ![]() ![]() ![]() |
I have been meaning to reply to this topic since my manifold split in October.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2648 ![]() ![]() |
My 2012 version of Microcat shows the MY13 L405 4.4 is fitted with manifolds with later part numbers than the L322 4.4. The earlier part numbers supersede to the later part numbers suggesting improvements in the design. As several upgrades to the 4.4 occurred late 2011 or early 2012, it is likely that the updated manifolds were fitted to later L322 engines.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
[quote="Baltic Blue"]I have just found this alternative diagram showing both RHand and LHand inlet manifolds.
