Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG
Page 1 of 6 123456>
Baltic Blue
Gents,
I have been thinking that some form of fault history/ log would be useful to owners and others looking to buy....
Some clever Excel type person could probably produce a spreadsheet based on my draft.
Members willing to contribute could then add their username and faults.
We would soon have a pretty good 4.4 td V8 fault history.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #447723 13th Aug 2017 6:00pm
and theres me hoping for a quiet week Laughing
good idea....i wonder if its workable..
[ pic sorted michael.. Wink] ... - .- -.
Post #447738 13th Aug 2017 9:34pm
MarkA
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
I can write an excel spreadsheet, just need to collate the data
Post #447750 13th Aug 2017 11:18pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Nice one! Add the (easy fix) adaptive dynamics fault. Thumbs Up Happy to chip in with the IT side too if you want. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #447765 14th Aug 2017 8:23am
nino_nino
BB excellent Thumbs Up Thumbs Up
Post #447771 14th Aug 2017 9:10am
Baltic Blue
Stan,
Have you had any thoughts how it may work?
I have seen a couple more reports of cracked plastic manifolds since my initial post.
I think we need to log them.
Cheers
Post #448923 24th Aug 2017 10:36am
morning Mike..
if an excel sheet was collated then how would a new item be added..would this excel sheet be downloaded?
if the title in a post had the correct wording and info then the forum search function would find the thread?
not sure how this will work unless someone can figure it out.... ... - .- -.
Post #448924 24th Aug 2017 10:43am
Baltic Blue
How about if Adrian (ajac8) produces and emails to me a blank spreadsheet; I am happy to enter any reported 4.4tdv8 fault details from posts I read , say once a month, and add the updated spreadsheet to this post ?
I just need a blank pro-forma that is suitable.
Post #448927 24th Aug 2017 11:09am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
You need one Excel spreadsheet in Dropbox, Google Drive, Microsoft OneDrive or similar that only the participants can edit but everyone can view. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #448928 24th Aug 2017 11:13am
Baltic Blue
I have been doing it bit more work on this whilst the weather has been so bad this week.
If any 2010/12 4.4tdV8 owners are willing to help me by supplying the data I would really appreciate it
The easiest way to do this would be to simply send me a PM with the following info.
Username or anon.
1) Model... e.g. Westie, 4.4 tdV8 Vogue, VSE, Autobiography
2) Fault report....e.g., Restricted Performance. iid fault code etc.
3) Fault cleared by.... eg replacing CHange over valve (CSOV)etc
4) Mileage at time of failure....
5) Any other helpful info.
I will eventually add a photo of the completed spreadsheet to this post for all to see, then update it as and when needed.
Cheers
Mike (Baltic blue) G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450694 12th Sep 2017 2:07pm
So far
Replaced squeaky belt at 47000
While they were:
Replacing leaking bottom oil drain push on fitting (was leaking when I had it at 34k)
Leaky turbo drain pipe at 47000 (tightened probably.....)
Put some new drop links on t at about 50000
Replaced front strut 44000 approx, only major component failure.
Rear shocks are leaking but they all do that sir.....
I could do with having the turbo drain mod done but can't be bothered at the moment
My changeover valve is the new one anyway
Apart from that it's been as good as gold. There is nothing that can't be fixed with a hammer😜😜
Post #450722 12th Sep 2017 6:59pm
Baltic Blue
Thanks NMJ.
I have added your info.
Split rubber manifold hoses are winning.
I have only had 1 Fault (stuck CSOV) in over 2 years. They changed the hoses at the same time.
Touching wood now out of warranty. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #450832 13th Sep 2017 4:34pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Things of note that I can currently recall are:
Drop link replaced at about 65k
Another drop link at 85k
There have been some other odds and ends but nothing of particular note that springs to mind.
I do however have a routine service coming up and have recently been experiencing the "Restricted Performance" warning but without any restricted performance which is odd. I have also over the last 2 or 3 years noticed the engine coolant level very slowly dropping over a number of months, but have never mentioned this to the garage and just topped it up myself. So I'll mention both of these and see where that leads things. If any remedial action comes of it I'll endeavour to update you on the outcome. 4.4 TDV8 Vogue Baltic Blue MY11
Post #450924 14th Sep 2017 5:41pm
software update for the '80' mph hesitation and the turbo drain valve mod, other than those my westie has been ok.. ... - .- -.
Post #450929 14th Sep 2017 6:04pm
Had the software too, got rid of the hesitation 👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #450947 14th Sep 2017 10:36pm
Page 1 of 6 123456>
