Home > Maintenance & Mods (L322) > Detailing Polisher - Advice
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
As some of you may be aware, i like to give my car a good clean and then wax so on.
Always done this by hand and am thinking of getting a machine to speed the waxing process.
I always use Autoglym products.
Would anyone have recommendations on polishers ?
Been looking at a DeWalt DWP849X-GB 150/180mm 1250W Premium Variable Speed Polisher which seems to be very good.
around the £160 mark.. any recommendations on pads/polishers you use ? for just applying and then buffing off.
thanks 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #447696 13th Aug 2017 10:01am
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
I have been wondering about this one...
http://www.argos.co.uk/product/4645777
Because I am a beginner Thumbs Up
Any thoughts ??
Post #447698 13th Aug 2017 10:22am
alistairh
I have this kit and it's been great..also comes with pads
https://www.ebay.co.uk/itm/121829368998
Post #447714 13th Aug 2017 2:35pm
mzplcg
Consider which of the 2 types of machine you are going to use, I.e. Rotary or dual action. I know little about DA machines but if a rotary is your thing a Makita 9237 is a well made bit of kit. I have 2 of them and they make progress quite rapid.
Post #447716 13th Aug 2017 2:38pm
stu
What's the difference between the two types? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447719 13th Aug 2017 3:25pm
Crispian22
If your looking to get into detailing,to start with I'd recommend getting a dual action,less likely to knacker the paint up which can easily be done with a rotary which requires more concentration and technic.
I use a meguires da with meguires compounds and finish off with autoglym high definition wax,the finish and beading of water last for months Thumbs Up
Post #447722 13th Aug 2017 3:55pm
stu
Thanks for the info Crispian Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447725 13th Aug 2017 5:24pm
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I purchased a Dodo Juice DA kit and have had really good results with it, plenty of info on YouTube to steer you in right direction, was a little nervou at first but seems you can't do much wrong with a DA polisher as compared with the old rotary ones, certainly gets rid of swirls on my Black RR paint, used Meguires Ultimate compound and a water spray from a trigger bottle stop it drying out as polishing, do part panel at a time, wiping off with microfibres cloth. 👍
Post #447726 13th Aug 2017 6:23pm
Crispian22
Look at this on eBay http://www.ebay.co.uk/itm/141917382151
This will be a safe option for paint correction Thumbs Up
Post #447727 13th Aug 2017 6:23pm
b348xyx
So i was looking at wrong type !
I need a DA unit, as i am no expert !
https://www.amazon.co.uk/Poorboys-World-PB...s+polisher
most likely what i need to get me started ! 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #447729 13th Aug 2017 6:38pm
Crispian22
Looks the sort of thing to get you started.
Don't forget your pads also.
Post #447730 13th Aug 2017 6:57pm
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Errm, what are he polishers they sell in Aldi (and are often remaindered) and why would they be no good?
Post #447756 13th Aug 2017 11:40pm
mzplcg
Those would be the mini 12 volt things as sold in Halfords, car boot sales etc. Being only 12v and also direct drive from the motor to the head they have very little torque. This is important to maintain a steady head speed with different pressures so as not to bog down and mar the paint.
The key to getting good results is to use as powerful and steady a machine as you can cope with. Combined with good polishing foam heads and a decent quality polish (not T-Cut) you will get a decent result. Also, with a less powerful machine you get much less in the way of results so the temptation becomes one of going to a much coarser polishing compound than is needed and you end up with holograms, almost like having spread wax on and not buffed it off properly.
Post #447763 14th Aug 2017 7:02am
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
I have one of those, they're mains powered and quite powerful for a cheap polisher. However, there's only one mop as such and two slip on covers to fit over it. They're orbital but not got much throw, so the pile on the head seems to take up the orbital throw to a certain extent.
For just general polishing they're ok, easier than hand polishing. On flat bits like roof and bonnet I dropped the polisher on a micro fibre cloth, so the polisher does the work. That brings up a real good shine Thumbs Up
Personally I'm thinking of knocking up some new mop covers oput of micro fibre cloths as I think they'll be better, be a decent tool then Thumbs Up
Post #447851 14th Aug 2017 6:07pm
mzplcg
IIRC Meguiars do a microfibre kit to go with their DA polisher.
Post #447892 14th Aug 2017 9:30pm
